Old 11-01-2013, 05:59 AM   #1
Send a message via AIM to Lucky Enough
How long should propane supply last?
Still a newbie at this stuff. Any ideas how long 30lb tank of propane will last? We have 8 weeks of trips thus far. I have used the furnace about 12 hours but have no idea how often the gas back up comes on for the hot water heater. The stove top is used very little. The gas grill probably has 15 hours of use. The two 30lb tanks in my windjammer 3008w are far from easy to access so I don't think a tank mounted gauge is my answer.
If I had known how much we could enjoy traveling in our windjammer, I would have started years ago.
Lucky Enough is offline   Reply With Quote
Old 11-01-2013, 06:13 AM   #2
dcheatwood's Avatar
Depends on your use of gas appliances. I'm still on the first bottle in my new rockwood since may. More than 5 weeks camping. But we'll use more as weather cools. Make sure to set you regulator to use only one tank at a time. When its empty, switch over and refill it. And enjoy. : -)
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 11-01-2013, 06:25 AM   #3
The last line what Dcheatwood said! Switch & Refill!! Youroo!!
Old 11-01-2013, 07:11 AM   #4
Patches's Avatar
Last winter when the temps stayed at, or below freezing during the nights, (and some days) we were going through a tank every 4-5 days. At $3.39 a gallon, it was a bit on the expensive side. Under normal usage (what's normal) we were getting 10-15 days from a 30 pounder. Warmer days, with out shore power perhaps as much as a month. Now that we are plugged into shore power, a tank will last 10-12 weeks, maybe more. My wife likes to bake stuff, and that is our primary use of LP gas right now. This winter we will heat with shore power. We cook with shore power, and the water heater works off shore power. Free electricity is a good thing.
"Full Timer" with "Boon Docking" in the desert southwest being my drug of choice. Well, that and really cold beer.
Patches is offline   Reply With Quote
Old 11-01-2013, 07:25 AM   #5
Free elect?? Youroo!!
Old 11-01-2013, 08:30 AM   #6
ryand's Avatar
Furnace use is by far the most consuming appliance of propane. I typically go through both bottles in a season. Water heater is next probably followed by the grill/stove top and the fridge should use the very least. If you could find data on the gas consumption of all the appliances and figure out the avg time they are used you could do a little math and estimate when the tanks would run dry. I like it keep it exciting and set the regulator to not change over when Tank 1 empties so that at least i never completely run out.
2011 Coachmen Catalina 28DDS
2015 Ram Bighorn 2500 6.4L
http://www.ryandethrow.wordpress.com
Nights Camped 2016: 32
ryand is offline   Reply With Quote
Old 11-01-2013, 08:31 AM   #7
AKA: 'tiredTeacher
awellis3's Avatar
He meant "already paid for electricity" I'll bet.
Teach
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 11-01-2013, 08:38 AM   #8
AKA: 'tiredTeacher
awellis3's Avatar
Lucky, those gauges measure pressure not volume. You'll have pressure right up to the moment you run out. If you do any mod to the propane system, get a sensor to tell you when the tanks have switched over so you know one needs refilling.
Here's a link to the mod: RV Propane Tank Changeover Indicator | ModMyRV
Teach
Wright and Penny
Richmond, Va.
Old 11-01-2013, 09:19 AM   #9
I've been doing mostly weekend camping (4-5 days at a time) for the last 20+ years. That would be both dry camping and in the winter months seek out campgrounds with full hook ups. Some of the tricks we've done to conserve on propane when dry camping is only run the water heater when we plan to shower and wash up dishes. We've found with this new rig, the insulation isn't quite as good and the heater kicks on a lot.
When hooked to shore power, we have a space heater to keep it nice and warm inside. We'll run the furnace first thing in the morning to get the damp and chill off, but limit it from running constantly. And the water heater has the electric option, so we can save on propane there as well.
So, doing a few things like that, we get 2 weeks + out of a 30 lb tank.
Hope this helps.
JSolomon is offline   Reply With Quote
Old 11-01-2013, 11:32 AM   #10
Owner/Operator
RodeoGeorge's Avatar
To directly answer the OP's thread title, until it's empty.
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
http://www.forestriverforums.com/for...ons-36212.html
RodeoGeorge is offline   Reply With Quote
propane
