Old 04-10-2011, 02:32 PM   #1
How many bolts hold your axels on?
I was under my 2011 2304s today cause slide motor died and noticed they used 2 bolts per side on each axel their is holes for 2 more bolts per side oneach axel above the others but were not used.I hope that is strong enough.4 bolts per axcel does'nt seam like much.
4runner is offline   Reply With Quote
Old 04-10-2011, 03:43 PM   #2
Our 1809s also has 2 bolts per side for each axle. All together there are 8 bolts to hold the 2 axles.
capucine is offline   Reply With Quote
Old 04-10-2011, 03:44 PM   #3
There is only one ubolt per side that the axle tube bolts to the spring pack with. There is only one bolt on each end of each spring. What more do you need? My spring hangers have three holes each, but they are for raising or lowering the trailer.
Old 04-10-2011, 04:05 PM   #4
You said that your slide motor died. Is it a wiring issue or is motor burned out? Seems premature for a motor to fail since the unit is a 2011. This connerns me since I also have a 2304s TT.
Bloomington MN
Rockwood 2304S
TV is a 2014 F150 5.0 V8 with Equal-i-zer
jwuertz is offline   Reply With Quote
Old 04-10-2011, 04:06 PM   #5
Donn: The trailers that uses the rubber ride suspension are this way. Each axle are mounted on a flat steel plate that is bolted to the frame L brackets. This bracket is welded to the frame. One thing is my trailer does not have 4 holes on this bracket but only 2 holes to fit the bolts from the axle.
Old 04-10-2011, 04:36 PM   #6
slide motor
I was doing a little cleaning today and went put the slide in and it struggled and blew the fuse and kept blowing them .Itook the motor out and took it apart and the gears were gone.My warranty ran out march 20th.Ill be calling forest river tomorrow my 2304s has had very little use.I also noticed none of the slide stops are adjusted correctly not even close.
Old 04-10-2011, 05:03 PM   #7
"There is only one ubolt per side that the axle tube bolts to the spring pack with. There is only one bolt on each end of each spring. What more do you need? My spring hangers have three holes each, but they are for raising or lowering the trailer."
Talk about a Homer Simpson moment. DOH!
I guess donn has never heard of the rubber torsion axles.
Actually, I wrote a post about this very subject, and how the axles can slip and rotate on the mounting plates, causing the tires of the related axles to lift. If only one axle slips and causes its tire to lift, that puts more weight on the other axle and tire. Not a desirable situation.
I solved the problem by drilling up through the axle flange where the camper frame rests on it. Actually, mine already had holes there, so I used them as a guide and drilled through the camper frame, then put 1/2 bolts in. I jacked up the camper, loosened the original mounting bolts, tightened the new bolts, which snugged the axle mounts tight against the trailer frame, then retightened the original bolts.
Now take note that where I say 'camper frame', it is actually the carrier frame for the torsion axles, and that in turn is mounted to the bottom of the trailer frame.
It all sounds a bit confusing, but anyone with these axles will know what I am talking about after they look under their camper.
Old 04-10-2011, 05:25 PM   #8
axels
I wiil be doing the same to my 2011 2304s
Old 04-12-2011, 03:49 PM   #9
DAISY BOYKIN's Avatar
Too many bolts on the axles.
Got a answer back from Forest River about my post on 4/10/2011 with pictures. Statement was made to me by FR, that it was not common for this to happen but unusual. was that the axles have to be realigned to
the frame by an alignment shop (I have an appointment for this to be done) to be sure axles run true. FR production mgr said, "whoever bolted the axles to the frame at alignment failed to torque properly" thus causing slippage. I will pay (under warranty) for the work, submit bill, get reimbursed. I also have other issues about the brakes that is on going also. I contacted a local company for the work that specializes in alignment, repair of axles and electric brakes. camping world didn't fix the brakes and another local BIG RV dealership attempted to repair.
So next Tuesday, I will take my toy to the axle and brake specialist for repair.
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 04-12-2011, 04:08 PM   #10
" Statement was made to me by FR, that it was not common for this to happen but unusual."
I find that EXTREMELY difficult to believe. I am an engineer, and there is no way I would design it that way. There is all of the weight of the trailer on those bolts, and they are supposed to hold only with a clamping force?
But please, report back to us what the alignment shop tells you.
That would be greatly appreciated.
