03-19-2016, 07:43 PM
How to use the ignitor on the indoor stove?
We bought our 23LB a year ago and used it last summer for the first time. We have the knob on the stove that is supposed to ignite the burners when the gas is turned on. We turned the gas on the burner and kept turning the knob so that it kept clicking but the burner would not light. I'm afraid to leave the gas on too long while it's trying to light. Can anyone tell me how to use it? Not sure if I'm doing something wrong or it's just not working.
2011 MicroLite 23LB
2012 Ram 1500 Crew Cab
03-19-2016, 09:20 PM
Very possible that the gas line has gotten air into it over the winter.
Suggest you get a butane lighter and hold it next to the burner, and let it run until it lights. It could take a minute or two until you get propane to the burner.
Once you've got propane to the burner, it should light normally.
Note that if this is the problem, you may also have to try to light off the water heater and furnace a few times until the gas gets through the lines to them, too. (Unfortunately, you can't use a butane lighter on those!)
UPDATE - It goes without saying that you should also make sure the gas is turned on at the tanks. Your propane regulator may also have locked up. See post #14 here about resetting it:
http://www.forestriverforums.com/for...t-46244-2.html
2011 Traverse LT, 3.6L, FWD
03-20-2016, 07:51 AM
I'm sorry, but I must have explained it incorrectly. Our stove lights fine when we use a butane lighter on it. My question was how to get it to light using the igniter knob on the stove. It would be much easier than using the butane lighter.
2011 MicroLite 23LB
03-20-2016, 07:58 AM
Lift the top of the stove up and check to see if the wire has fallen off the igniter, ours did that all the time.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
03-20-2016, 08:09 AM
Gold Miner At Heart
We have always just used a 11" butane lighter instead of the clicker. I've never liked lighting the stove with the clicker. Even with a new unit.
“I have tried to live my life so that my family would love me and my friends would respect me. The others can do whatever the Hell they please!” —John Wayne
03-20-2016, 09:36 AM
electric BBQ starter
I removed the clicker style starter and replaced it with a BBQ electric starter from wally world. Very easy task. Cost about $15
2011 2902ss Rockwood Ultralight
2008 Grand Cherokee 3.0L Diesel (255 hp @ 2900 rpm / 430 lb-ft @ 1,400-2,800 rpm)
3P ProPride Hitch
RV Mods
Wandering RV Life
03-20-2016, 10:12 AM
HikerBob
Ditto on checking the wires from the ignitor to the burners. Two of ours were not inserted in the ignitor sockets when we lifted the stove pan under the burners. We also have a butane lighter for campfires.
03-20-2016, 10:25 AM
Georgia Rally Coordinator
Also try one of the other burners and turn the knob real fast. later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
03-20-2016, 11:58 AM
Location: Full timer,,,at Lake Georgetown in central Texas for the winter.
DDC and Hikerbob are probably the solution to your problem. I've also had wires fall off the electrode terminal under the burner top. You want to have fun? Hold the end of the wire while you're clicking the ignitor....that'll tell you for SURE is you're getting a spark.
03-20-2016, 12:11 PM
Thanks, everyone! I'll check it out when we get to the camper the next time. Hopefully I can get the top of the stove lifted up. Is it difficult?
2011 MicroLite 23LB
03-20-2016, 12:24 PM
Push and lift.....or is it pull and lift?
03-20-2016, 01:08 PM
I did the same and it works great!
VMI'62
03-20-2016, 01:19 PM
Retired Techie
Try the igniter in the dark with lid up. If you see sparks jumping wrap wires with black tape (lengthwise is easiest). Worked wonders for mine
2005 Wolf Pack WP22
2016 Grey Wolf 26RR-Traded in
2004 Siverado 2500HD Duramax Sold w225,000
2013 Keystone Springdale 5r Sold
1998 Honda Valkerie Sld
2016 Camping 148 days so far Bought park model and moved to Florida.
03-20-2016, 01:23 PM
Push top to the back and lift up front centre....
03-20-2016, 01:30 PM
Also check the gap on the electrode. About 1/8 inch works.
03-20-2016, 02:14 PM
HikerBob
We have a 2011 Rockwood MiniLite etc 181, so I can't be sure if our stove is the same as yours, but no it's not difficult. But use a rag under the front lip to keep from cutting your fingers when you raise it off. I would NOT use a screwdriver as you could easily chip the enamel. It has a clip retainer in the front center and two little "L" brackets at the back that have to be aligned and inserted fully when replacing the top. I also replaced the little screws (or were they rivets) in the hinges for the stove cover with cotter pins, as they fell out over time.
03-20-2016, 06:43 PM
EXACTLy X 2
Floyd & Carolyn
2012 F150 S/crew 4X4 6.2L 6Spd Tow Max Firestone airbags. 2011 28RKS Wildcat. Yamaha 3000iseb Gen.
2014 57 nights.2015 116 nights .2016 96 nights .2017 72 nights. 2018 157 nights. 2019 52nights.2020/21 118 nights. 2022 115nights
03-20-2016, 07:09 PM
They don't work well
I hate those turn igniters. They just don't work very well.
I drilled a 3/4 inch hole and installed a battery powered igniter from eBay. It keeps clicking until you let go. The problem with the other ones is that the gas needs the spark at just the mixture of oxygen and gas, and it seldom does.
The new igniter is quiet, and it lights every time.
03-20-2016, 07:55 PM
Did the same thing. Got a battery powered igniter for a three burner grill from Wal-Mart. Wife loves it.
03-21-2016, 07:48 AM
I removed the clicker style starter and replaced it with a BBQ electric starter from wally world. Very easy task. Cost about $15.
My igniter works just fine but the piezo electric is a cheesy outdated thing. I told the wife the same thing. Our Gas Grill has a 1 AA cell right on the button and ignites quite easy and quick; why not having one on the stove is beyond me.
However, as a backup, in case that you are in a zombie appocalipse, in the boonies, with enough propane and no batteries or matches, or lighter, or flint will be nice to have the piezo clicker....
2016 Rockwood 2306
2016 Chevy Colorado Z82 / 2009 Pontiac G8 GT
