Old 10-19-2015, 07:19 AM   #11
Will have to see if we can take it to one, can you they use a photo of the paint as well?
wrsantos is offline   Reply With Quote
Old 10-19-2015, 07:32 AM   #12
Originally Posted by wrsantos View Post
its the piece by the bedroom door, trim along bottom of trailer, color is mocha but having a hard time matching the color,
A Pic is real Helpful,there are several pieces by the Bedroom door,some are Plastic,some are Aluminum,some are coated sheet metal! You say a Scratch,will this have to be Repaired/Filled befoe Paint? All lower body parts can be Removed/Replaced. Sidewall damage is a Back to Factory Job! Paint match is the easy part,repair is the more involved part! Youroo!!
Old 10-19-2015, 07:51 AM   #13
it a lower piece along the bottom of the trailer, not good at describing this, but its plastic trim, thank you
Old 10-19-2015, 07:52 AM   #14
RedLdr1's Avatar
No, unfortunately. The reason is not all cameras, printers, and PC's are equally capable of showing an exact color. And just being a couple shades off can be very obvious...
When we had our "W" full body paint touched up under warranty the body shop still used a spectrophotometer even though I had the OEM paint codes.
Wayne and Christine
2019 Sunseeker 2500TSF Pending Delivery...
2018 Ford Focus SEL Hatchback TOAD
RedLdr1 is offline   Reply With Quote
Old 10-19-2015, 07:54 AM   #15
thank you
Old 10-19-2015, 02:16 PM   #16
Christ follower
Look up an automotive paint supply like Sherwin Williams Automotive Paints. Give them the paint code and they can put it in a spray can for you for about $30
7.3Excursion4x4 is offline   Reply With Quote
Old 10-22-2015, 10:56 AM   #17
If all you want is to match the color for repair any good auto paint supply house can custom mix you an aerosol can to make the repair.
Sent from my XT1080 using Tapatalk
tstillman1 is offline   Reply With Quote
Old 10-22-2015, 11:21 AM   #18
Thank you, we were able to get this fix
