Old 04-17-2016, 09:42 AM   #11
fonzie's Avatar
Originally Posted by leefl View Post
Thanks, nice idea, however unfortunately I always leave a couple of gallons of water in the black tanks to avoid them drying up, and don't have anywhere to dump that either at the storage lot or at home
You can do same by pushing air down toilet hole......
Fonzie
Old 04-17-2016, 02:26 PM   #12
jheacox1's Avatar
I have the same feeling, but since the tanks are fairly big, it could feasibly be the other side (if I were laying out the camper I'd put the black vent as far away from the ceiling fan as possible, but it may be wishful thinking to assume that FR designers had such thoughts)
I forgot that you have the lighter color camper. Ours is the Diamond package which has the darker exterior, where I guess yours is the Platinum package. Otherwise identical
Yeah Platinum with Convenience Package F. Upgraded AC to 15,000 BTU as well.
I'm going to smoke test that toilet next weekend and see which vent is which.
2015 Rockwood Signature Ultra Lite 8281WS
2015 F250 Crew Cab
jheacox1 is offline   Reply With Quote
Old 04-17-2016, 03:31 PM   #13
leefl's Avatar
2015 F250 Crew Cab
Seems like ours are almost identical except the exterior color. I forget the specific options but I think we have everything available except 2nd a/c
Ours has a mfg date of Jan from one of the stickers, but was bought in late summer
leefl is offline   Reply With Quote
Old 04-17-2016, 08:14 PM   #14
jheacox1's Avatar
Yeah we're identical except you're Champaign colored. Cherry cabinets too right?
2015 F250 Crew Cab
Old 04-17-2016, 08:20 PM   #15
jheacox1's Avatar
Oh and I tried to send these pics via PM but the server kept erroring so here they are. Hope it helps.
2015 F250 Crew Cab
Old 04-17-2016, 08:36 PM   #16
HerveVR's Avatar
If you have two or more vents, there is no harm to install cyclone vents on others than the black tank one.
If the position of the vent makes it too tight to install «Cyclone vent» look also for this one; it is static but the desing gives confidence. Look for more information from forumers.
https://www.rvupgradestore.com/360-S...-p/31-0230.htm
HerveVR is offline   Reply With Quote
Old 04-20-2016, 09:55 AM   #17
leefl's Avatar
Thanks for the photos (sorry I forgot to reply after seeing them on my phone)
Looks great. I think I might have to put an order in.
Is that a spray-in bedliner ? or a "bed rug" ? (I'm guessing a spray-in, since it looks like it goes under the rails)
I have the Ford plastic bed-liner (dealer included it) which I cut 2 slots in for the bed rails. Great in theory, except that it buckled up around the front corner (I guess just because there's less material keeping it straight), and stuff gets underneath it (grease from hitch, pine needles etc), tho' I am thinking of making a cover to go over the bed rails and around the hitch legs (just some thin corrugated plastic)
I think the problem with sending the photos was that my inbox was full, so I cleared out a few messages.
2015 Rockwood Signature UltraLite 8281WS
2016 Ford F-250 Lariat CrewCab, 4x4, 6.2L V8
Old 04-20-2016, 10:14 AM   #18
fonzie's Avatar
Did you figure out your vents as per your original question?
Fonzie
Old 04-20-2016, 10:27 AM   #19
Flybob's Avatar
If you are going to try the essential oil suggestion, be very careful. Essential oils are very concentrated can damage many surfaces. I use essential oil of peppermint for rodent prevention, but always contain it in an old ceramic coffee cup.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-20-2016, 10:38 AM   #20
bubbles's Avatar
To me that is one ridiculous place to route a vent. If it were mine I would get some pvc and glue in an extension to get it above the vent cover. Just saying.
black, black tank, tank, vent
