Old 04-16-2016, 06:48 PM   #1
leefl's Avatar
Identifying black tank vent vs gray tank vent 8281WS
I'm considering putting cyclone vents on our black tank vents, but I notice that one of the front bathroom vents is extremely close behind the bathroom fan/vent cover.
I'm hoping someone could tell me whether that is the black or gray tank vent ?
Looking from the back of the 5er the bathroom is on the right hand side, nearest the door, and there is one vent pipe on that side, near the ceiling fan/vent, and another vent pipe on the opposite side.
Any help identifying which is which would be appreciated, since if I put a cyclone vent cap on the right-hand vent pipe it would likely hit against the fan cover, but the other one would be clear.
No need to put a cyclone on the gray tank vent cap.
I'm hoping they wouldn't be stupid enough to put the black tank vent right near the ceiling fan, but it wouldn't surprise me
leefl is offline   Reply With Quote
Old 04-17-2016, 06:21 AM   #2
fonzie's Avatar
You could always use a vacuum shop and push air through the black tank drain valve and see which vent air comes out of it......
Fonzie
Old 04-17-2016, 07:19 AM   #3
jheacox1's Avatar
Here's a pic of the vent leefl is referring to.
After looking at it bud I have a feeling it's a black tank vent. It lines right up with the wall behind that toilet. Good thing my fan only blows out in that bathroom.
2015 Rockwood Signature Ultra Lite 8281WS
2015 F250 Crew Cab
jheacox1 is offline   Reply With Quote
Old 04-17-2016, 08:12 AM   #4
nomad297's Avatar
Put a bottle of cinnamon oil in your black tank. You will definitely smell it. It is used by plumbers to help locate sewer gas leaks. Of course, our first choice is a smoke test.
Bruce
Old 04-17-2016, 09:07 AM   #5
leefl's Avatar
I have the same feeling, but since the tanks are fairly big, it could feasibly be the other side (if I were laying out the camper I'd put the black vent as far away from the ceiling fan as possible, but it may be wishful thinking to assume that FR designers had such thoughts)
I forgot that you have the lighter color camper. Ours is the Diamond package which has the darker exterior, where I guess yours is the Platinum package. Otherwise identical
2015 Rockwood Signature UltraLite 8281WS
2016 Ford F-250 Lariat CrewCab, 4x4, 6.2L V8
Old 04-17-2016, 09:08 AM   #6
leefl's Avatar
Thanks, nice idea, however unfortunately I always leave a couple of gallons of water in the black tanks to avoid them drying up, and don't have anywhere to dump that either at the storage lot or at home
Old 04-17-2016, 09:10 AM   #7
leefl's Avatar
Bruce
Interesting idea. I guess my concern is that it might stink out the camper if left in there until I next have a chance to dump the tanks (likely not before our big trip in 7 weeks)
Old 04-17-2016, 09:11 AM   #8
nomad297's Avatar
Then put the hose down your toilet.
Bruce
Old 04-17-2016, 09:12 AM   #9
nomad297's Avatar
Peppermint oil is another option. Maybe that wouldn't be so bad.
Bruce
Old 04-17-2016, 09:29 AM   #10
dieselguy's Avatar
Just climb on the roof and have someone flush the toilet ... you can easily hear the water drop in the tank while listening at the vents.
dieselguy is offline   Reply With Quote
black, black tank, tank, vent
