Old 09-24-2016, 01:34 PM   #11
leftyneil's Avatar
6X on oxygenics. They make a number of shower heads. Purchase the oxygenics Fury for RV. It has a shutoff valve on the handle.
leftyneil is offline   Reply With Quote
Old 09-24-2016, 01:39 PM   #12
Unscrew the hose from the faucet. There may be a restricter washer, one with a small hole. Remove the washer and see if that makes a difference.
tom3205 is offline   Reply With Quote
Old 09-24-2016, 01:45 PM   #13
Hoffwmn's Avatar
Is it OK to use the water pump AND campsite water together? Does it damage the pump in any way?
Hoffwmn is offline   Reply With Quote
Old 09-24-2016, 01:49 PM   #14
Ford Idaho's Avatar
I doubt it will hurt the pump but what it may do is cause the check valve in the pump to not work as it should and that will cause the fresh water tank to fill and then overflow.
Ford Idaho is online now   Reply With Quote
Old 09-24-2016, 01:56 PM   #15
We use an eco camel shower head to increase water velocity
wjrdmr is offline   Reply With Quote
Old 09-24-2016, 02:45 PM   #16
NMWildcat's Avatar
I don't know why you would use both at the same time. When we are at a park with low pressure we fill the fresh tank and just use the pump. Only had to do that about 4 times in 25 years
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 09-24-2016, 02:48 PM   #17
CANADA FROG RALLY 2017
B and B's Avatar
I find most campgrounds have reasonable pressure. I send mine through a disposable filter, water softener, then the FR internal filter. This works for me, never use a pressure regulator.
B and B
2013 Rockwood 8289 Diamond Edition
GY D's/2.5 inch lift kit/Powerhouse 4 KW EFI Generator
2016 Ford F 350 Lariat Power Stroke Diesel Crew Cab FX4
2008 Golden Falcon 380PA Park Model Model
"Oh Canada,True North Strong and Free!"
Old 09-24-2016, 03:31 PM   #18
Oxygenic Shower head
Which model of Oxygenic shower head do people prefer?
Curlydoc is offline   Reply With Quote
Old 09-24-2016, 03:36 PM   #19
Shower
Agree 100% Oxygenics. You can also increase pressure by running your water pump. Just make sure you have water in the tank.
Bob & Sue Rowan
Okeechobee, FL
2012 Coachmen Mirada 29DS (SOLD)
2015 Keystone Bullet Travel Trailer
2016 F-150 Lariat with Auto Trailer Backup
Dog = Morki (Yorkie-Maltese) - Zoe
Malabarbob is offline   Reply With Quote
Old 09-24-2016, 03:49 PM   #20
ccsvolsfan's Avatar
I carry a pressure gauge with me and check h2o pressure before hooking up. I can't remember the last time I needed to regulate pressure down. By the time it runs through the two in line filters and the h2o softner the pressure is never over 50#.
ccsvolsfan is offline   Reply With Quote
pressure, show, shower, water
