Old 09-24-2016, 02:57 PM   #21
Ditto Oxygenics but also upgrade to this regulator, https://smile.amazon.com/dp/B003YJCE9E. It's going to give you 55 to 60 PSI as opposed to the 45 PSI in a standard regulator (which usually really only give you 35 to 40). Any modern RV can handle 60 PSI.
2016 Rockwood Signature Ultralight 8329SS Platinum
2016 GMC Sierra 2500HD Denali Crew Cab Duramax
TXFolkie is offline   Reply With Quote
Old 09-24-2016, 04:13 PM   #22
ARLO
Remove the restrict or..
rlocicero is offline   Reply With Quote
Old 09-24-2016, 05:34 PM   #23
Charles Firth's Avatar
I always check the campground water pressure. I have not found one over 50lbs yet. My pressure at home is 60psi. If the pressure is within tolerance I do not use the regulator. I have almost no pressure if I use the regulator. My next purchase is an Oxygenics shower. I am really check out other people setups at the campground, I see very few regulators used. I also see only a few surge suppressors used, at least not at the pedestal. Just my observation.
Chuck " still in Va "
2012 3065w Windjammer
2012 f250 lariat Crew cab power stroke (of course )
Charles Firth is offline   Reply With Quote
Old 09-24-2016, 06:56 PM   #24
J.shea
I had the same problem with my 2015 Evo. There is an O ring washer at each end of the shower head hose. Unscrew the shower head from the hose and the hose from the faucet. On mine one of the o rings was crushed and protruding into the water stream. New washers can be found at Ace Hardware. Fixed the problem.
J.Shea is offline   Reply With Quote
Old 09-24-2016, 07:00 PM   #25
Boso's Avatar
Shower
Oyygenics and take the little made in filter off at the water inlet on the inlet just inside the fitting
Boso is offline   Reply With Quote
Old 09-24-2016, 07:31 PM   #26
Back On The Go
Same problem, and I bought an adjustable pressure regulator (amazon: Valterra A01-1117VP Brass Lead-Free Adjustable Water Regulator). Tried it at home after the last trip and it has made a world of difference in the shower at 55 lbs pressure. Our next RV outing is in 3 weeks so will test it at campground then.
2016 Georgetown 270S
2013 Ford C-Max Hybrid
2 Janis Hybrid Bicycles
Not too serious about anything except what affects health and happiness.
salwolfe is offline   Reply With Quote
Old 09-24-2016, 07:57 PM   #27
Georgia Gets Around
frugalbk's Avatar
Shower Water Pressure
Originally Posted by ben31 View Post
First off, we upgraded to the Oxygenics shower head. We also keep some water in my fresh water tank. When the site has extra low water pressure, I turn on the water pump and use both the water pump and the city water. The shower is then wonderful!
By accident, I experienced this same thing this summer. When you want a better shower, turn on water pump. But remember to refill your fresh water tank before leaving on the road because toilets don't refill without water available! Experience this too by accident!
2015 Georgetown XL 369
2005 Jetta TDI on ACME Dolly
frugalbk is offline   Reply With Quote
Old 09-24-2016, 10:35 PM   #28
Nurek's Avatar
Thanks for all your replies fellows!!!
I tried to remove the flow constrictor last night with tweezers, but some needle nose pliers made the job easier and ripped it out moments ago.
Flow looks better already. I'll test the shower shortly to see how better it is.
When I get back to civilization, I'll look into the upgrade.
2011 Nissan Xterra
2016 Rockwood MiniLite 2306 First ever RV.
Nights Camped 2016 [24]
Nights Camped 2017 [tbd]
Nurek is offline   Reply With Quote
Old 09-24-2016, 11:49 PM   #29
That's exactly what we have done.
OldBob
I may be old but I'm trying, very trying.
2015 RAM 1500 - EcoDiesel
Rockwood Ultra V 2715VS
OldBob is offline   Reply With Quote
Old 09-25-2016, 11:52 AM   #30
And, remember, if you remove flow restrictions, tanks will fill faster. 🤔
Rollingdunder1 is offline   Reply With Quote
pressure, show, shower, water
