Old 10-06-2016, 07:33 PM   #41
Chuck
I love my Oxygenics!
Idaho_Chuck is offline   Reply With Quote
Old 10-06-2016, 09:27 PM   #42
What 12vdc pump did you go with?
roodman is offline   Reply With Quote
Old 10-06-2016, 09:48 PM   #43
We purchased a high flow water pressure regulator and our shower pressure improved a great deal. We've been looking at those oxygenics shower heads but just haven't picked one up yet.
JerryGigiSev is offline   Reply With Quote
Old 10-06-2016, 10:15 PM   #44
Canadian Member
itat's Avatar
I replaced my old pump with this one:
https://www.amazon.com/SHURflo-4008-.../dp/B002XM5G70
There was a noticeable difference in pressure and it is quieter, too.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer
2016 Ford F-250 XLT SuperCrew, 6.2L, 4x4, 6'9" bed, 3.73
Fondly remembered:
2009 Ford F-150 XLT SuperCrew, 5.4L, 4x4, 5'6" bed (2012 - 2016)
Old 10-06-2016, 11:25 PM   #45
Outstanding. Will get one thx..mike
Old 10-10-2016, 10:54 PM   #46
Global Nomad
Scheinin's Avatar
[QUOTE=Charles Firth;1325795]I always check the campground water pressure. I have not found one over 50lbs yet.
How do you check the campground water pressure?
Steven J. Scheinin
2015 RAM 3500 4X4
6.7L CTD Dually pulling a
2016 Cedar Creek 36CKTS
Scheinin is offline   Reply With Quote
Old 10-12-2016, 02:40 AM   #47
Croaker's Avatar
My Oxygenics makes the water come out too fast and slams me against the shower stall when I push the button.
Croaker is offline   Reply With Quote
Old 10-12-2016, 07:43 AM   #48
jeff
jeff64's Avatar
Originally Posted by chaslorr View Post
I was under the impression that you should not run your water pump while hooked up to city water.....am I wrong?
No, you are not wrong and usually the potable tank is empty anyway when I'm hooked to city water
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 10-12-2016, 08:05 AM   #49
Witch Doctor's Avatar
[QUOTE=Scheinin;1338393]
Get a 10.00 rain bird water pressure gage. screw it on the spigot and read the CG water pressure. I then set my regulator to the max pressure but never over set it past 50 lbs. Reason is that if it's on the well the pressure could fluctuate to 65 lbs, depending on the CG and people using it.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 10-17-2016, 07:23 PM   #50
Charles Firth's Avatar
I check the pressure at the hydrant next to the camper that I will be using for my water supply. Depending upon the pressure ( over 50psi) will dictate if I use the pressure reducer of not. I have one just in case but it really does not get much use. Don't know if I am doing it right, but seems to work for me so far.
Chuck " still in Va "
2012 3065w Windjammer
2012 f250 lariat Crew cab power stroke (of course )
Charles Firth is offline   Reply With Quote
pressure, show, shower, water
