Old 08-26-2015, 07:55 PM   #1
Installing BAL Hide-A-Spare on a Mini Lite
I bought a BAL Hide-A-Spare, model #28217 (for 70-75” RV frames). Got it on Amazon. Here’s my experience installing it. The instructions are not all that great. This will take a few posts for all the pics I took.
Pic #1: As it came out of the box.
Pic #2: The only bolts it came with are the ones to hold the spare to the mounting plate between the tubes. I called BAL and they said they don’t supply bolts to bolt it to the RV frame “because we don’t know what your frame looks like.” Seems like a bit of a cop-out to me. No mention of this in the Amazon ad. I bought four sets of 5/16 x 1-1/4” bolts with a flat washer, a lock washer and a nut. I could have used ¾” bolts, as the RV frame is only about 1/8” thick, but they had me worried and figured, “better too long than too short.”
Pic #3: You have disconnect the hinge side mounting plate from the tubes and reconnect it in a vertical postion. It’s attached in a manner that allows it to ship flat. No mention of this in the instructions.
Pic #4: There are 3 holes in the mounting plate and 2 bolts. The spacing between the holes is not identical. You have to pick the 2 holes that match the spacing of your spare. (Of course, it was the last of the 3 option I tried that fit!)
Pic #5: Here’s the spare mounted front down. I thought this would allow me to check air without having to drop it down. See Pic #6.
Name:	Hide a spare 1.jpg
ID:	87015   Click image for larger version
Name:	Hide a spare 2.jpg
ID:	87016   Click image for larger version
Name:	Hide a spare 3.jpg
ID:	87017   Click image for larger version
Name:	Hide a spare 5.jpg
ID:	87018   Click image for larger version
Name:	Hide a spare 6.jpg
2011 Traverse LT, 3.6L, FWD
Old 08-26-2015, 07:56 PM   #2
Pic #6: This shows you how much space I have to get to the air valve –not a lot. So after I got it all done, I think it would be better mounted face up, then drop it to check the air. (But I haven’t flipped it yet.)
Pic #7: The frame of the device consists of an inner tube and an outer tube. When you drop it down, you can slide it out from under the trailer. These little do-dah’s keep the inner tube from coming fully out of the outer tube. Only problem is that if you get this far, you’ll have to crawl under the RV to push these back in so you can slide the spare back.
Pic #8: Here’s the hinge side mounting plate bolted to the RV frame. I forgot to check behind the frame and hit my wiring, but fortunately, it didn’t hurt it any.
Pic #9: Here’s the mounting plate on the curb side bolted to the RV frame. I had to use a lower set of holes because my propane line ran behind the upper set. (Good thing I did the other side first – I’d have run a drill right into the propane line!!!!)
Pic #10: Here’s the curb side all hooked up. The locking knob has a cotter-pin like device that goes into a hole on the bottom so it can’t unscrew itself. You could run a lock into the hole instead if you were worried about theft. Or just install a bolt and nut. (This would make it basically the same at the bumper-mounted spare tire holder. Everything on those is just bolts/nuts.)
Name:	Hide a spare 7.jpg
ID:	87020   Click image for larger version
Name:	Hide a spare 8.jpg
ID:	87021   Click image for larger version
Name:	Hide a spare 9.jpg
ID:	87022   Click image for larger version
Name:	Hide a spare 10.jpg
ID:	87023   Click image for larger version
Name:	Hide a spare 11.jpg
Old 08-26-2015, 07:57 PM   #3
Pic #11: I shot some black primer/paint on the bolts.
Pic #12: I was able to put the spare tire cover back on the tire, so hopefully it stays a bit cleaner.
Name:	Hide a spare 12.jpg
ID:	87025   Click image for larger version
Name:	Hide a spare 13.jpg
Old 08-26-2015, 08:21 PM   #4
Brother Les's Avatar
Very nice write up and pictures.
I bought a hide-a-spare a couple of years ago, as I wanted two spare tires. One on the bumper and one 'out of the way until needed'. My assembly came with no attaching bolts or screws and no bolts to hold the tire on. To hold it to the frame, I used 6 large metal screws on each side. drilled a slightly smaller pilot hole and then screwed them in tight.
As for the tire under the unit, I have no cover on it and it still looks brand new, with no road debris or mud any where.
It is your unit, but I would suggest to at least put in one more bolt on each side or put in a couple of heavy duty metal screws.
Brother Les
Old 08-26-2015, 08:26 PM   #5
I think I should be OK.
In THEORY, the flange of the frame takes the weight. The bolts just keep the mounting plates from coming away from the web. So they're not really weight-bearing, nor will
they see any shear stress.
But I'll keep an eye on it.
Is your tire face down or face up? Any thoughts there?
Old 08-26-2015, 08:40 PM   #6
Who Dares, Wins
doc73's Avatar
Very cool. I just saw this the other day and was thinking of getting one. Quality is good? I saw them for about $100 or so.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 08-26-2015, 08:50 PM   #7
Quality seems good. Brother Les can probably say better as he's had his for a few years.
Old 08-26-2015, 08:53 PM   #8
Looks to me like it would be better to have the tubes slide thru the inner bracket rather than telescope or take the buttons off completely if there isn't room for sliding tubes. Don't think I'll be installing one in the near future.
Old 08-27-2015, 07:52 AM   #9
The flange does take the weight. I have checked my metal screws and a couple have backed out a little and I re tightened them. Even resting on the flange there maybe a slight side to side movement. There are three different styles of attaching side plates of Hide a spare. One is flat and does not have the built in lip for trailers that have flat beams and no flanges, so if anyone orders one, make sure that it is correct for your unit. (my first one sent to me was wrong and would not fit).
I have mine mounted with the stem facing up to the under belly. I think less chance of debris hitting it than if it was facing down. The 'clip pin' takes a little maneuvering to get off, but I think that it is good to 'drop' the tire to the ground and check it to make sure the tire pressure and complete assembly is fine and working good at home than 'on the road'.
As for the quality, it is fine. No mounting bolts/screws came with it, so I have to 'figure' out what I wanted to use. There is some surface rust starting along the edges, but no black paint is peeling, no big deal. I need to take a wire brush to it and spray some kind of black metal paint on it and it will be fine.
I have mine mounted to where it is under the Fresh water tank drain and breather hose. Just a slight more protection to where the hoses will not get caught onto something. It is mounted in front of the first axle (brush guard ). I have a very high base camper so there is no worry of the tire framing getting close to the ground and hitting anything. If you have a low frame unit, this setup may not work.
Brother Les
Old 08-27-2015, 07:58 AM   #10
I am a CW member. I went to the nearest store and they ordered it for me to be sent to their store at no shipping cost. I asked if it could be shipped directly to me at no cost shipping and he said sure.
Brother Les
Old 08-27-2015, 08:14 AM   #11
(Dry Huunday)
DreiHunde's Avatar
Nice install and thanks for all the pics!!!!
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
DreiHunde is online now   Reply With Quote
Old 08-27-2015, 12:16 PM   #12
I put one on my 5th wheel, when I got the tire mounted on it and went to put it back into position I realized it was not easy to do. I fabricated a lift jack to lift it into position because once down with the tire on it it was damm heavy....
Bob Vaughn is offline   Reply With Quote
Old 08-27-2015, 12:25 PM   #13
This is my next project on the 5th wheel. Glad to hear the quality is good.
Filthy Beast is offline   Reply With Quote
Old 08-27-2015, 12:39 PM   #14
I used self tapping steel metal screws.....put socket on impact drill and had both panels installed within minutes.....Pain in the but to use bolts!!!!!!!!!!!!!!! J
Jim in Halifax is offline   Reply With Quote
Old 10-25-2015, 08:00 AM   #15
leefl's Avatar
Nice write-up.
Unfortunately I don't think this would be so easy with my 5er, since the frame is pretty much completely covered. There might possibly be space with enough exposed frame, right at the rear, I'll check next time I'm at the storage lot
2015 Rockwood Signature UltraLite 8281WS
2016 Ford F-250 Lariat CrewCab, 4x4, 6.2L V8
leefl is offline   Reply With Quote
Old 10-25-2015, 10:48 AM   #16
pfeather1's Avatar
Looks like it should work ok but might be heavy to lift into place. Think I'll just keep mine in the truck bed where I do now
pfeather1 is offline   Reply With Quote
Old 10-26-2015, 07:15 PM   #17
Blackhat6mike's Avatar
My Aviator came stock with this system and I keep 2 spares on it. After my 3 blowout trip last year, I'm considering a third spare in the PU bed. Who would have thought I would have had three blowouts in 350 miles. Glad I didn't have to spend the night in lower Miami off the edge of the road.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 10-26-2015, 07:17 PM   #18
leefl's Avatar
What could you possibly be implying about certain Miami neighborhoods ?
Old 10-26-2015, 07:31 PM   #19
Who Dares, Wins
doc73's Avatar
This system is on the short list for me. I want to loose the spare mounted on the rear cargo rack. After the axle flip ground clearance of the rack is not longer an issue but I just do not want to deal with it.
2015 ChevyHD D-Max
Old 01-20-2016, 11:06 AM   #20
dmdomokos's Avatar
I have a 2702WS and can't decide if I should mount this in front of the axles or behind them. Any suggestions?
dmdomokos is offline   Reply With Quote
