Old 08-12-2011, 08:02 AM   #1
DAISY BOYKIN's Avatar
Installing gas piston-------------
Installing gas piston lift to my cargo doors to make life a little bit better.
How many times have you been in your cargo storage area and the door or hatch falls on you?
This my fix to not only stop the door from falling on your head, it also upgrades your RV.
I have found all the parts, gas pistons, screws, brackets on the Internet at several different places that makes it economical to order and install your storage/ hatch gas pistons yourself.
Here are some of the photos of the installation and finished product on my 8285WS.
If you would like the info for your RV PM me?
Name:	Gas piston lift 010.jpg
ID:	7343   Click image for larger version
Name:	Gas piston lift 011.jpg
ID:	7344   Click image for larger version
Name:	Gas piston lift 012.jpg
ID:	7345   Click image for larger version
Name:	Gas piston lift 001.jpg
ID:	7346   Click image for larger version
Name:	Gas piston lift 002.jpg
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 08-12-2011, 08:09 AM   #2
More pictures of the gas pistion installation------------
Additional pictures of the gas piston installation: Takes about 45 Min's to install the necessary items for each door/ hatch. The screws listed are available at Home Depot, 3M tape is also available at HD in a 15' roll. for all other items PM me.
Name:	Gas piston lift 003.jpg
ID:	7348   Click image for larger version
Name:	Gas piston lift 005.jpg
ID:	7349   Click image for larger version
Name:	Gas piston lift 004.jpg
ID:	7350   Click image for larger version
Name:	Gas piston lift 007.jpg
Old 08-12-2011, 08:19 AM   #3
jimh's Avatar
i like the idea. looks like it would solve the problem of the door (while open) slipping from the catch and braining u while ur digging something out.
concern i would have would be it coming open while traveling.
came up behind a trailer that had sliding drawers inside cargo area and failed to latch them and the door. somehow, the drawers slid out and hit a bridge railing. drawer and door were demolished.
on mine, the door is made out of a thin piece of al sheet metal on the inside and a thin piece of fiberglass on the outside. the inside is Styrofoam. the real bracing is in the rim that goes around. looks like u solved the thin metal with a large pad to attach to.
jimh is offline   Reply With Quote
Old 08-12-2011, 08:32 AM   #4
Something that does not show---------------
Something that does not show that I failed to mention is the 3M double back tape that is applied to the whole back surface of the 4" square, 22 gage galvanized sheet metal. It is the gray 3M tape with the red peel off backing, not the white tape.
Old 08-12-2011, 09:01 AM   #5
sfrye5853's Avatar
That's a great idea! Need to put that on my list of things to consider.
2005 Ford Expedition 5.4 4x4
2012 Tracer 3150BHD
sfrye5853 is offline   Reply With Quote
Old 08-12-2011, 09:08 PM   #6
For anybody that would like to buy all the parts required in one kit, go to this website.
HatchLift
phoneman06 is offline   Reply With Quote
Old 08-13-2011, 04:40 AM   #7
But my purchase of parts--------------
But my purchase of the parts cost 1/2 of the whole kit ???????????
Old 08-18-2011, 09:44 PM   #8
sundawg's Avatar
Where did you get your parts at?
Paul, Marcia, Calyn, and Josie
2 Goldens- Asti and Ryan
1 Sheltie- Jackie B
2007 Expedition
2011 Forest River Greywolf 26BH
sundawg is offline   Reply With Quote
