Old 06-23-2015, 12:20 PM   #1
Installing screen door handles
Our Rockwood Ultra-Light 2608WS screen door only has a small black plastic loop on the inside of the camper to grab onto when closing just the screendoor. So we purchased the Camco Screen Door Crossbar. This attaches with four small screws to both sides of the screen door.
Has anyone attached this to their screen doors before? Will the small screws be enough to handle the abuse of opening and closing the screendoor? Not sure if there is any blocking within the screen door frame or not and just concerned that the screws may eventually pull out of the aluminum screen door frame.
Any thoughts?
tntbream is offline   Reply With Quote
Old 06-23-2015, 12:28 PM   #2
GlacierGus's Avatar
I am now in my 4th season with mine and it has not loosened up at all. Works for me.
2013 Rockwood Mini Lite 2109S
2006 Dodge Durango Hemi 5.7
Equal-i-zer WDH
GlacierGus is offline   Reply With Quote
Old 06-23-2015, 12:41 PM   #3
Georgia Frog Rally 2018
aceinspp's Avatar
I just installed one yesterday. It's note made to lean on or play monkey bars it is pretty strong as mounted. I put mine just above the opening that you mentioned. Just follow the instructions. Very easy and looks nice. It is now easier to grab the bar to close the screen door. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 06-23-2015, 12:55 PM   #4
Got them on both doors on our 2819VS Windjammer.
Work Great.
____________
MK Clark
2014 Silverado
2015 2819VS Windjammer
MKClark is offline   Reply With Quote
Old 06-23-2015, 12:57 PM   #5
brookstone345sa's Avatar
I purchased a flat 1" wide piece of aluminum from local hardware store. I attached that to door screen frame and then attached pushbar to that. I used short self tapping screws.
brookstone345sa is offline   Reply With Quote
Old 06-23-2015, 01:05 PM   #6
Timex's Avatar
I used the screws provided. Is holding up well. But I don't use the bar to close the whole door apparatus and seal the latch when locking the door from inside. I thought it might be a little to much stress on it. I use it for another towel rack as well.
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
Timex is offline   Reply With Quote
Old 06-24-2015, 12:51 PM   #7
Have used this product on last rig and now on current rig. In both cases used supplied screws with no problem. Great addition.
ottawapaul is offline   Reply With Quote
Old 06-24-2015, 02:12 PM   #8
burch42's Avatar
i installed the crossbars today on both my screen doors, seems pretty sturdy the way they are. very easy install too!
burch42 is offline   Reply With Quote
Old 06-24-2015, 03:40 PM   #9
The screen and main door on our Flagstaff hook together when closed, and swing as one unit.
After I installed the screen door handle we tended to shut the entire door/screen unit by grasping the new bar handle. We had to remember to manually unhook the outer door from the screen door to prevent the screen door handle from breaking off.
If you shut the door combo by using the new handle on the screen door, the factory handle will eventually fail. You are pulling the outer door closed via the new handle on the screen door, and putting too much force on the plastic screen door handle which connects to the outer door. Ask me how I know the factory will break !!
To prevent accidental handle breakage I fashioned an aluminum latch hook that holds the two doors together. Now we simply unhook the latch when the only screen door is being used, and keep it latched when we close the combo..
Henboy is offline   Reply With Quote
Old 06-24-2015, 06:00 PM   #10
Jeffco, MO
tedstr's Avatar
Pleae provide a picture pf your aluminum latch hook. Thanks.
Mary & Ted
2016 Silverback 33IK
2015 GMC Sierra 2500HD CrewCab Diesel/Super Glide Hitch
Days camped 09 -53, 10 -56, 11 -57, 12 - 55, 13 - 46, 14 - 50, 15 - 60, 16 -32
7 FROG Rallies (Goshen(4), Charleston, Amana(2))
tedstr is offline   Reply With Quote
door
