Old 04-23-2016, 04:47 PM   #11
Dazed & Confused
M&K Hoffman's Avatar
Our Windjammer came with a towel bar mounted on the swinging bathroom door. It is 18" wide and is screwed into the solid edges of the door. We could put up to a 24" bar on the door.
~Mike & Kim~
2014 Rockwood Windjammer 3008W Diamond Package
2012 Toyota Tundra Doublecab 5.7 4WD
M&K Hoffman is offline   Reply With Quote
Old 04-23-2016, 04:52 PM   #12
gectisme's Avatar
X2
2016 Windjammer 3006WK
2010 Dodge Ram 2500, 4x4, Diesel, Front Hitch, Air Lift 5000 Rear Air Bags, (not really used, left over from our truck camper). Equalizer E4 1.4k/14k WD Hitch. TST 507 TPMS. Furrion FOS48TA Observation Camera. Garmin RV-760 GPS. Honda 2000i Genny, PI EMS-PT30C.
MISSION COMPLETED!
gectisme is offline   Reply With Quote
Old 04-23-2016, 05:41 PM   #13
HikerBob
Originally Posted by Augustpilot View Post
New 2906WS, want to install towel bars on sliding door. Looking for ideas on fastening the bars to door, since most of the door is hollow. I know a lot of you have done this so appreciate your suggestions.
Jim
How do you put anything on a sliding door? it seems to me it would hit the door jam and keep the door from closing.
HikerBob is offline   Reply With Quote
Old 04-23-2016, 05:52 PM   #14
crunchman12001's Avatar
I thought I was the only one that saw that. I figured it could be interesting to watch. Lol
2015 F-250 FX4
Old 04-23-2016, 07:00 PM   #15
Dazed & Confused
I guess I would put it on the side away from the wall, unless it's a pocket door, which I highly doubt. My Windjammer has a swinging door on one side of the bathroom and a sliding door on the other side. I could put a towel bar on the sliding door, but it would be on the bedroom side of the door.
~Mike & Kim~
Old 04-23-2016, 07:25 PM   #16
shughey00's Avatar
Jim
I put two towel bars on my bathroom door. Since the towel bars did not go to the edge they did not hit the solid wood in the edge so....the screws pulled out when someone leaned on them a bit.
I suppose if you made sure or could get a towel bar that is the right length so the screws hit the outer inch of the door then you would hit the wood core.
Solved that by doing what someone else said. I bought a nice piece of hobby oak at lowes and cut it the length of the bar. mounted the bar to that then I had enough contact area to mount it to the door. Now..I used 6 screws and counter sunk them and made it nice nice.
I am the oddball out...I am not a huge command strip fan. Not knocking command strips as I do use them here and there.
Anyway I mounted two bars on the back of the door as I had nowhere else to do it actually. So there is a bar above the one in the pic near the top of the door. I don't like towels laying on each other or they wont dry so..ya know had to separate them.
After I thought you could also get a towel bar that is slightly longer the the width of the door and cut the bar down so the brackets fit to the door edge. The bar is hollow brushed nickel would take 30 seconds with a hacksaw to cut it to the exact length.
shughey00 is offline   Reply With Quote
Old 04-23-2016, 07:33 PM   #17
I have a swinging door and screwed two towel racks directly into to it. No problems after 5 years and over 20,000 miles. There are always wet towels on them when we travel. They must be on there pretty good.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 04-24-2016, 12:37 AM   #18
Campground host Mo. State
Photogirl's Avatar
If its a sliding door how will it slide with a towel rack mounted on it?
Frank & Kathy & Daisy 2.0 Yorkie (Pack leader)
2008 Ram 6.7 Diesel, 4.10 diff., EGR valve delete, MBRP straight exhaust, Mini Max race tuner, K&N
2016 Crusader 321 RES Ham call W0FCG
Days camped in 2015- 111 in 2016-75 in2017-61
Photogirl is offline   Reply With Quote
Old 04-24-2016, 01:05 AM   #19
RangeMaggotBob's Avatar
Nice job; looks really sharp.
2015 Forest River Rockwood Signature Series Ultra Lite 8289WS w/Diamond pkg.
2014 RAM CTD 6.7 Tradesman 4WD Auto Crew Cab Long Bed
Honda eu2000i generators
RangeMaggotBob is offline   Reply With Quote
Old 04-24-2016, 05:50 AM   #20
Sorry not enough info, it hangs from top and slides inside on bathroom wall. It is not pocket door. One side of door is always exposed. Only place to hang a rack in this design.
Jim and Silene
2017 Rockwood 2906WS
2014 Dodge Ram 1500 Hemi 5.7
Firestone Airlift 1000, Equalizer Hitch
Augustpilot is offline   Reply With Quote
door, roo
