Old 03-12-2016, 04:53 PM   #1
RusLwt001's Avatar
Integrated Brake Control Setup
I have a 2016 Windjammer 3025W (32'). I recently bought a tow vehicle that has an integrated brake control system;however, to set the controller up I have to select from four choices of type of brake. I looked on other posts but just can't find this information, I even went on the Nev-R-Just brakes (Drexler's) web site and don't see it. Can anyone tell me which of these choices I should make?
1. Light Electric
2. Heavy Electric
3. Light Electric over Hydraulic
4. Heavy Electric over Hydraulic
If you can point in the right direction I would appreciate the help. Thanks.
Russ
2016 Rockwood Windjammer 3025W
Diamond Package
2016 Ram 2500 6.4 Hemi 4x4
RusLwt001 is offline   Reply With Quote
Old 03-12-2016, 05:15 PM   #2
Left Coast
Number 2.........Really!
Old 03-12-2016, 05:24 PM   #3
RusLwt001's Avatar
Thank you Bob. I'll set it up tomorrow.
Russ
Diamond Package
Old 03-14-2016, 01:03 AM   #4
Hi Russ I bought the flagstaff 30wikss V Lite which is the 3025w twin sister. Same floor plan different interior colors and fabrics. You will want to set the brake controller to 2. The brakes will need to break in before they will reach good braking power. If you go to the top of this page there is a link called library in the lite green bar at the top of this page. The library has lots of information on how to take care of your trailer and how things work. There is good information on the brakes and how to brake them in.
Hope this helps Tim
TimVWulp is offline   Reply With Quote
Old 03-14-2016, 08:16 AM   #5
Usually Confused Member
emm-dee's Avatar
The Ram owners manual has a sorta description in section five. They say Light Electric for 10k or less, Heavy Electric for over 10k. Although the difference is very slight I've noticed Heavy Electric seems to apply the brakes just a bit quicker.
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
emm-dee is online now   Reply With Quote
Old 03-14-2016, 11:49 AM   #6
RusLwt001's Avatar
Thank you everyone. I didn't get a chance to setup yet.
Russ
Diamond Package
Old 03-14-2016, 02:47 PM   #7
Appalachian Ed's Avatar
Where do you all put your trailer brake gain? Mine is on +4. Frankly I cannot tell a lot of difference in +4 and +8. Braking seems pretty normal for hauling 9000 pounds to me so I don't really worry about it and leave it at +4.
Ed
2015 Rockwood 8289WS
2009 Ford F-250
Appalachian Ed is offline   Reply With Quote
Old 03-15-2016, 12:53 AM   #8
Normally you would set the gain to where you can squeeze the brake actuator all the way on (+12 meaning applying 12 volts to the brakes) and the trailer brakes are just short of locking up at 25 mph. My present setting (RAM EcoDiesel with 6000 lb trailer) is +8.5.
OldBob
I may be old but I'm trying, very trying.
2015 RAM 1500 - EcoDiesel
Rockwood Ultra V 2715VS
OldBob is offline   Reply With Quote
Old 03-15-2016, 06:27 AM   #9
53flattie's Avatar
Mine is set to 5.5.
2015 Rockwood 2306
2015 Tundra CrewMax
53flattie is offline   Reply With Quote
brake control, brakes
