Old 11-16-2017, 12:10 PM   #1
paverdave's Avatar
Interior ceiling trim
New 8299bs Rockwood crown molding is coming loose..The brads look to be 22ga...I have some 18ga brads but might be to big, don't want to do much cover-up work....does anyone know the right size to use? Thanks....
Dave...Northern Nevada
2018 Rockwood 8299bs
2007 GMC 2500HD Diesel SLT short bed w/gravity flow75 gallon Fuel Tank.. Cat delete
Firestone Airbag Ride Rite system
paverdave is offline   Reply With Quote
Old 11-16-2017, 12:21 PM   #2
Not sure if on inner or outside wall but just be sure if you use bigger brads they don't go clear through the outer wall. Those outer walls are not very thick.
Maybe a dab of liquid nails?
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 11-16-2017, 12:26 PM   #3
paverdave's Avatar
The ones I took out look to be 1" brads...so I'm going to go with the same size...Thanks
Old 11-18-2017, 05:47 PM   #4
paverdave's Avatar
Wanted to bump this up....must be a finish carpenter or someone that has worked on inside ceiling trim...would 18g brads be to big?......
