Old 07-21-2015, 07:25 PM   #21
Jhochst's Avatar
Great idea!
Originally Posted by CharlieWD View Post
We have a 2015 Micro Lite 25DS and I had tried all the suggestions to get the light covers off. I wasn't strong enough to squeeze the ends together to pop them off and was afraid I would break something if I tried to pry them off. I took my husbands Quick-Grip clamp - the kind that have kind of a pistol grip that you squeeze and the clamp tightens- slide the jaws apart until they fit over the cover the long way(so you are going to be squeezing the ends together) Squeeze the trigger until it grips the edges of the cover then squeeze some more and pull down and it comes off.
Jhochst is offline   Reply With Quote
Old 07-29-2015, 09:40 AM   #22
dudleydoo's Avatar
CharlieWD, thank you, it worked! They certainly don't slide off since the on/off switch is in an opening. Now I just would like to find a new light that is softer or a way to color the plastic cover to soften them. They give off some butt ugly light.
Bonnie and Rich
Oconomowoc
Winston (Rat Terrier)
Digby (Lhasa Apso)
2014 Shamrock 23IKSS
dudleydoo is offline   Reply With Quote
Old 02-07-2017, 12:29 PM   #23
Originally Posted by airfix View Post
Ok. I finally figured it out. Pretty much the opposite of the old style.You have to squeeze the 2 ends towards each other, causing the sides to bow out and release the 4 latches. Here are photos with the lens removed for clarity.
We are not able to push the ends enough to make the clips push out to take the light cover down. Any further suggestions?
Fred and Kay is offline   Reply With Quote
Old 02-17-2017, 09:20 AM   #24
Flatblade screwdriver
I put a flatblade scredriver between the side of the lens and the frame. Twist it slightly, and it should release the tabs.
2015 Rockwood 2604WS
2013 Ford F-150 FX4 Supercab, 3.5 Ecoboost V6
disenberg13 is offline   Reply With Quote
light
