10-18-2013, 09:47 PM
Interior oval light lens removal
Anyone know how to remove the lens from an interior oval led ceiling light on a 2013/2014 Rockwood Windjammer 2609? Just want to clean pieces of insulation from it.
10-18-2013, 09:57 PM
I want to know too, been trying but didn't want to break it.
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
10-18-2013, 10:10 PM
On mine. You squeeze slightly and slide away from the center or outward. Mine come off real easily if they are the same.
2017 Puma 297RLSS
10-18-2013, 10:43 PM
Push up slide away from the center. It will feel like it is going to break the first time but keep pushing away from the center.
kz08h5
2008 Chevy Silverado 2500 Duramax Crewcab
Jeep Commander - sold
Flagstaff V-Lite WRB26
10-18-2013, 10:44 PM
This new style is a single oval lens surrounded by a plastic bezel. Not like the ones that used to be common place.
10-19-2013, 06:02 AM
Pictures always helps members to make recommendations.......
Fonzie
10-19-2013, 10:13 AM
Here's a photo of this interior ceiling light:
10-19-2013, 10:18 AM
I would use both hands side by side, grip the lens in the middle with finger and thumb tips and squeeze while pulling down.
10-19-2013, 11:16 AM
Got it!
Ok. I finally figured it out. Pretty much the opposite of the old style.You have to squeeze the 2 ends towards each other, causing the sides to bow out and release the 4 latches. Here are photos with the lens removed for clarity.
03-16-2015, 01:04 PM
Great job!!
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
8-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
03-25-2015, 08:09 PM
Anyone know where I can buy matching light fixtures?
Linc
2014 Rockwood Windjammer 3006WK
2014 Ram 1500
03-28-2015, 01:47 PM
Found the lights on ebay for $19 or at the dealer for $35.
Linc
2014 Ram 1500
03-28-2015, 03:24 PM
Thanks airfix. Been trying to remove mine for same reason. Knew they had to come off but did not want to break them.
05-05-2015, 08:40 PM
All the squeezing I could muster up didn't budge the covers. So I found a screw driver and inserted into the openings and pried the covers off.
Does anyone know if the lights can be replaced with ones that are a little softer? I can't stand the harsh light the factory ones give off. Is it an easy job to replace them? Hope it's not as hard as removing the covers.
Bonnie
Bonnie and Rich
Oconomowoc
Winston (Rat Terrier)
Digby (Lhasa Apso)
2014 Shamrock 23IKSS
05-07-2015, 01:23 PM
Bonnie these will not budge. They are filled with sawdust. Did you pry it off at the little spaces? Did it go back on? Thanks Sue
05-07-2015, 01:24 PM
Are we talking about the ring around the lens or just the lens ?
05-07-2015, 01:30 PM
Boss Ox & Drovergirl
Bonnie
Yes, lesser watt bulbs are made, you should be able to get them at a RV dealer. I replaced most of mine. The other option I did for over the bed was to mask off the inside lense about 3/4 with aluminum foil. That gave bright light to read but not to interrogate my spouse!
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2016 GMC 3500HD Duramax dually
1992 Goldwing Aspencade
05-07-2015, 04:39 PM
Sue, I did get one off but haven't tried any others and have not tried to put it back. I can't figure out why they should be so hard to remove and reaching up to the ceiling isn't that easy. I did pry off at the little indents.
Bonnie and Rich
Oconomowoc
Digby (Lhasa Apso)
05-07-2015, 09:49 PM
The lenses actually slide off.
07-21-2015, 05:06 PM
Remove lens cover
We have a 2015 Micro Lite 25DS and I had tried all the suggestions to get the light covers off. I wasn't strong enough to squeeze the ends together to pop them off and was afraid I would break something if I tried to pry them off. I took my husbands Quick-Grip clamp - the kind that have kind of a pistol grip that you squeeze and the clamp tightens- slide the jaws apart until they fit over the cover the long way(so you are going to be squeezing the ends together) Squeeze the trigger until it grips the edges of the cover then squeeze some more and pull down and it comes off.
