Old 10-17-2015, 06:51 PM   #1
J Wrap trim caulking
I have the RV in my signature. The caulking along the top of the 1" trim, where the J Wrap/panel is attached to the sidewall along the passenger side, started with a 6" crack and has now grown to several feet. Does this cause a water intrusion problem or is it cosmetic? I'm curious if this is from flexing from normal travel or cold/heat. I'm taking the RV into the dealer on Monday for warranty work and want to have them fix it while they have it.
2015 Rockwood 8329SS TT
2004 Chevy 2500HD D/A 4X4 CC SB
Andersen Weight Distribution hitch
lakejumper is offline   Reply With Quote
Old 10-17-2015, 07:27 PM   #2
Islander's Avatar
Can you attach a picture?
I'm sure it would be more than cosmetic....along the top, as you describe.
Definitely have your dealer repair it.
Islander
'07 WildCat 30 RLBS ~ West Coast Edition ~
Trail Air - Tri Glide Pin Box
2000 F350 Lariat DRW 4x4 7.3 Diesel 89k miles
Edge programmer, 4" SS exhaust turbo/back,
Tru-Cool Max Trans Cooler, Bilstein Shocks
Vancouver Island, B.C., Canada
Islander is offline   Reply With Quote
Old 10-17-2015, 08:39 PM   #3
dougk53's Avatar
That trim covers a metal channel that the J Wrap goes behind and screws go through the channel and J Wrap to secure it to the bottom of the trailer. The caulk keeps water from infiltrating behind and possibly into the screw holes. Happens often so try to keep some no sag caulk of the appropriate color in the trailer so you can fix when you notice in the future.
Doug
Doug, Virginia, Buster & Sam
2017 Ram Crewcab 2500 6.4 Hemi Delmonico Red Pearlcoat
2015 Flagstaff 27RLWS
2005 Road King
5 Grandkids
Brianna,Frankie,Tyler,Tori&Jocelyn
dougk53 is offline   Reply With Quote
Old 10-21-2015, 08:21 PM   #4
The dealership fixed the problem. There is aluminum sheeting that is about 7-8 inches wide that runs between the J-panel and the sidewall. FR didn't put enough staples in it and didn't place them close to each other, resulting in a slight bulge. It's all fixed now!
caulk
