Old 05-25-2016, 03:45 PM   #1
Jack knife sofa replacement
Has anyone replaced the sofa in a Mini Lite 2502KS?
BOZO1 is offline   Reply With Quote
Old 05-25-2016, 05:20 PM   #2
No but I did add plywood under mine because of you sat down in the last 18 inches from an end you would sink down, way down.
2016 Flagstaff 23lb
Toddupton is offline   Reply With Quote
Old 05-25-2016, 09:46 PM   #3
I need to do something to my sofa also. 2504s. It feels like its "understuffed". What thickness of plywood did you use and how did you mount it? On top of the springs? Thanks in advance. Jay
Jay2504 is offline   Reply With Quote
Old 05-26-2016, 05:32 AM   #4
I used 1/2 inch plywood between the springs and the foam all the way to the ends and just use 1/2 staples around the springs to hold it. I just used scrap plywood about 12 inches wide.
2016 Flagstaff 23lb
replacement
