Old 08-31-2016, 02:09 PM   #11
Jim34RL's Avatar
We also have used child locks in the past on are other 5er; but they have not been required on our Cedar Creek as of yet.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, 100K+miles
Old 08-31-2016, 02:22 PM   #12
We have had three trailers over 20 years and towed thousands of miles. Never had a cabinet or drawer open. Make sure the latches are adjusted properly.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2017: 4 nights camped, 12 booked
Teamfour is offline   Reply With Quote
Old 08-31-2016, 02:33 PM   #13
nikita's Avatar
The DH bungee cords EVERYTHING!!! That was after a trip home crossing the North Grand Island bridge while they were in the process of re-surfacing the whole thing. It was like xcountry skiing over moguls, we didn't realize and he was going full speed. Everything opened up and came falling out. Something like that will probably never happen again, but he still bungee cords everything.
Nikita
2011 Chevy Silverado Diesel 2500HD
2015 Sabre 33 RETS 5th Wheel
nikita is offline   Reply With Quote
Old 08-31-2016, 02:36 PM   #14
Toy-aholic
I had one door that would always pop open...added a second latch thingy like the original (one top, one bottom) problem solved
2005 GMC Sierra 3500 SLT DRW 6.6 D/A FOR SALE
2013 Crusader 335BHS TE FOR SALE
EXGMTech is offline   Reply With Quote
Old 08-31-2016, 07:42 PM   #15
Double Ball Latch
This seems to be the most durable, and adjustable latch for securing cabinet doors and drawers. You local full-service hardware store (not the big boxes) may have them in multiple sizes. They allow installation for two directions, so versatle, but placement has to be pretty much exact. There are screws to set the tension on the balls, so you can set the release tension to your needs.
Example:
Double Ball Catch, Solid Brass | HardwareSource.com
Steve
2015 Prism 2150 LE / Sprinter 3500
cruncher is offline   Reply With Quote
Old 08-31-2016, 07:52 PM   #16
Originally Posted by BaldEagle81 View Post
Hello all,
Most of my drawers and cabinet doors have popped open at one point or another while traveling. Anyone have any good suggestions that work to fix this problem. Latches? Magnets? Homemade contraptions?
Wife made some 1 inch Velcro strips for cabinet doors that work great looped thru door handles. Have not had any problems with drawers.
2016 Wildwood 230BH X-Lite
2011 Ford XLT Supercab
2015 Days Camping : 6
2016 Days Camping : 32
2017 Days Camping : 11
Sebourn is online now   Reply With Quote
Old 08-31-2016, 09:57 PM   #17
I use properly sized T-handles bolted through the cabinet/drawer frame adjacent to the opening side of the door or next to the drawer. Bolt head inside the cabinet and jam nut against the bottom of the T-handle so the assembly turns together without un threading the handle. Parallel to the edge to open, perpendicular to hold closed.
DRiveWell is offline   Reply With Quote
Old 08-31-2016, 10:34 PM   #18
RetiredRVer
Example:
Cruncher....could you provide photos of your installation of these latches? Thanks!
Joe & Sandy
Mentor, Ohio
2015 Chevy 2500HD Crew Cab 4X4 6.0 "Gasser"
2014 Wildwood Heritage Glen 282RK TT
2018 "FROG!" To Alaska
checkmate99 is offline   Reply With Quote
Old 08-31-2016, 11:59 PM   #19
Velcro
We had had pantry doors and closet doors coming open. They where located behind the slide outs when closed. Almost lost the doors!!!. Put a small piece of velcro each corner two years ago. No problems since.
Windjammer 3025
2015 Silverado Duramax
Dylan1972 is offline   Reply With Quote
Old 09-01-2016, 04:37 AM   #20
DouglasReid's Avatar
the only drawer we have problems with is the sliding drawer underneath the small couch. We use our rubber chock blocks to do double duty, the tires when we are parked, the drawer when we are traveling.
Maurice, LA
2012 Wildcat Sterling 32RL
2008 Chevy Silverado 2500HD LT Diesel
TST TPMS system w/ Flow-thru sensors
2001 Cougar 281 EFS (sold)
DouglasReid is offline   Reply With Quote
door, travel
