Old 12-20-2015, 10:42 AM   #1
leak under my bathroom sink
I have a 2014 Windjammer 3025W. I have a leak under my bathroom sink on the Port side. I've looked and checked everywhere and can't find the source. My outside shower is not and never has been hooked up. The hoses, which I can trace all seem to be dry. The only place I think it may be coming from is the pump. Has anyone ever heard of one leaking? If so where might I fine the best quality and deal for a new one?
wardcl1 is offline   Reply With Quote
Old 12-20-2015, 10:57 AM   #2
Platokidd's Avatar
Did you take a look at the pump to check for leaks? And yes they can leak.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Platokidd is online now   Reply With Quote
Old 12-20-2015, 11:01 AM   #3
Is the Leak (Inside or Outside)? Where is your O/S shower located ? Do you mean the Factory never completed hooking up the shower? Youroo!!
youroo is online now   Reply With Quote
Old 12-20-2015, 11:39 AM   #4
Forester Fred's Avatar
Location: On the road between New Hampshire and Florida
Is the check valve/vacuum breaker for the black tank flush (if you have one) in that area? Mine is under the bathroom sink and leaked because the guys at the factory didn't tighten up the fittings.
2015 Forester 2301 - Chevy
Skip & Deb - Bridgewater, NH & Delray Beach, FL
Forester Fred is offline   Reply With Quote
Old 12-20-2015, 12:22 PM   #5
Pickin' & Campin'
Wardcl1,
We are going to need a little more info and/or some pictures as some of what you mentioned seems confusing.
You mention your outside shower has never been hooked up?
Does that mean you never have used it or they didn't hook the plumbing to it from the factory? If you've simply never used it, you might take a look at it anyway. Sometimes the valves have a way of vibrating open slightly and it will drip inside the compartment and then leak inside the camper when the plumbing is pressurized.
You also mention your pump might be leaking. Is it located in the sink cabinet? Pumps can leak (somewhat rare) but if it's located elsewhere other than the sink cabinet then probably not the pump.
Outside black tank flush plumbing often has the back flow check/anti-siphon valve located in the bathroom sink cabinet and more of those seem to leak than do not.
Give us additional information, otherwise we are just guessing.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 12-20-2015, 12:25 PM   #6
Pickin' & Campin'
BTW... I see this was your first post.
Welcome to the forum!
Old 12-20-2015, 02:10 PM   #7
Location: Full timer,,,at Lake Georgetown in central Texas for the winter.
I have a 3029 Windjammer and the base of my lavatory faucet was leaking and also the checkvalve under there was leaking. Another leak I found was taking off the panel at the base of the shower and found the P connecter was loose. Check all that.
Grampa Jim is offline   Reply With Quote
Old 12-20-2015, 02:40 PM   #8
The OP has a 3025 his Bath is in the front with 2 sinks,yours is a Center bath with i sink! Youroo!!
Old 12-20-2015, 03:15 PM   #9
Ya know your stuff, Youroo.
Old 12-20-2015, 05:16 PM   #10
OscarsMom2's Avatar
We had a leak under the sink of our Rockwood Mini-Lite. It was from the sink drain. The factory forgot a gasket on the drain assembly. You should check the drain pipe by filling the sink with water and then pull the plug. That is how we found ours.
2017 Wildcat Maxx 26BHS
2016 Rockwood MiniLite 2503S (2015-2016)
2012 Ford F-150 Eco-Boost
OscarsMom2 is offline   Reply With Quote
roo, leak
