Old 06-01-2013, 10:10 PM   #1
Nights Camped in 2010 - 2
Leaking around hw drain/anode
Hello,
Has anyone ever experienced water leaking around the HWH drain/anode on a Suburban HW. I found some water under the HW after flushing the plumbing. I flushed and cleaned the HWH as well and seem to be getting some water leaking back through into the stowage compartment from around the collar. I don't see a gasket or caulking.
George Kelly
2011 Rockwood Ultra Light 2604
Dodge RAM 1500 Larime 4x4, 5.7 HEMI
Nights Camped 2010 = 18
Nights Camped 2011 = 15
sailingsuppo46 is offline   Reply With Quote
Old 06-01-2013, 10:15 PM   #2
Dave_Monica's Avatar
The anode rod/plug is a pipe thread and only requires teflon tape and proper tightening to seal. Perhaps it needs to be removed, re-taped and re-installed.
Dave
Old 06-01-2013, 11:12 PM   #3
Owner/Operator
RodeoGeorge's Avatar
If the HW heater is installed correctly, a leak from the anode rod will not flow into the RV, but will remain in the outside pan and if anything flow down the outside of the RV. The same with seepage from the Pressure and Thermal Safety Valve.
As Dave suggested, re-seal the rod installation with either teflon tape or pipe seal, and then put a paper towel under the rod port to absorb any water should it continue to leak. If the towel remains dry, and you still have water inside, it would point to a leak from a connection on the back of the water heater, or in worse case a leaking tank itself.
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
http://www.forestriverforums.com/for...ons-36212.html
RodeoGeorge is offline   Reply With Quote
Old 06-02-2013, 06:29 AM   #4
H2oski
X2 on the seeping Thermal Safty Valve at the top of the tank. Drain all the water out of the HW tank with the valve in the open position, then close the Thermal Safty Valve and refill. It needs and air pocket at the top of the tank.
Wife
2007 Chevy 2500 HD 6.6
2012 Sabre 31RETS
(LA) Lower Alabama
h20ski is offline   Reply With Quote
Old 06-02-2013, 07:03 AM   #5
I have had this happen to several campers especially when they get older. The female fitting on the bottom of the water heater will eventually rust and mineral deposits get into the threads when you drain the tank. If it sits through the winter with the plug out it will be even worse by spring. I use a small round wire brush (the type you clean the inside of a battery terminal with) and give the threads a good cleaning then reassemble it like they said above. I once had one so bad I had to borrow a pipe tap to clean it up. It becomes a problem when you dry camp and the little drip causes your water pump to cycle, running down your battery.
comfun1 is offline   Reply With Quote
Old 06-02-2013, 07:37 AM   #6
mduff's Avatar
What happens without the air pocket? I used the safety valve to confirm the tank was full after the winter prior to turning it on (opened to release air at the top).
Mike and Brenda
TV - 2013 Silverado 1500, 5.3L
TT - 2012 Wildwood 26 TBSS
mduff is offline   Reply With Quote
Old 06-02-2013, 08:06 AM   #7
Tilly's Avatar
mine seems to leak too
but only sometimes and it's around the outside of the insert which is threaded for the anode to go into, not through the threads. And it only does it sometimes. I've had it leak down so far I could hear the water gushing into fill the tank. Can't figure out what makes it happen / not happen.
2013 Sunseeker 2300
Chassis: Chevy 4500
Toad: 2004 Shadow Aero
"On the Road" since 8/8/12
Every Day's a New Adventure!
Tilly is offline   Reply With Quote
Old 06-02-2013, 09:06 AM   #8
Thanks All. I used some food coloring this morning and found the leak. It was coming from the gap between the unit and the face plate. It's three years old and I should have checked that to start with. Good news. HWH seems fine. I dug out all the old caulking and applied a nice liberal amount on silicone, flexible caulking. I should be gtg and be able to get out next week. Cheers. George
George Kelly
Old 06-02-2013, 03:10 PM   #9
H2oski
Nothing will "happen" other than the Thermal Safety Valve may seep. Glad you found it.
Wife
2012 Sabre 31RETS
(LA) Lower Alabama
Old 06-03-2013, 09:08 PM   #10
mduff's Avatar
Thanks.
Mike and Brenda
