Old 03-26-2016, 06:11 AM   #1
Level then slide or slide then level
Hi
We are going to pick up our new 8289ws on monday.
The refrigerator is in the driver slide out.
Do you deploy the slide, then level to fridge or level then deploy?
Thanks!
Some must watch while others must sleep
drstimpy is offline   Reply With Quote
Old 03-26-2016, 07:09 AM   #2
Fulltime family RVer
Level first. You may find that you need that side a touch higher, but you'll need to do it a couple of times first.
But, without a leveling system - how would you level after deploying the slide? Surely you're not going to move the camper with the slide out to drive up onto boards. And the stabilizers aren't meant for leveling...
Old 03-26-2016, 07:21 AM   #3
Georgia Frog Rally 2018
aceinspp's Avatar
X 2 Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
aceinspp is online now   Reply With Quote
Old 03-26-2016, 07:22 AM   #4
RSchleder's Avatar
We find that the side of our TT with the 2 slides needs to be 1 orange block higher than the other side prior to putting the slides out. We set it up that way, put the stabilizers down, push out sides the the trailer levels in a few hours as the slides side spring settles down a bit.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 03-26-2016, 07:27 AM   #5
Witch Doctor's Avatar
X's 2 you never want to deploy a slide unless you are level already, they stress and will bind on you. If you have one slide and your know that you will not be level after, then you will have to compensate for it like a board on that side. ependydad is correct, he might not be a wrencher as he's stated in other post but he does know about the correct way from trial and error, I have been following his post for a long time now.... It's just a learning curve that we all go through...
Coachmen M/H
Concord
2018 / 300 DSC
Old 03-26-2016, 07:29 AM   #6
Ependy is exactly right. Always level first! There can be undesired forces by moving the coach with the slides out. They are not designed for that. Also, FYI, always, always make sure kitchen drawers and cabinet doors are closed before moving the slide. I had to learn this lesson the hard way several years ago. Lucky for us that I have built cabinets before, so making repairs was easy.
On our new fiver, my wife found some U style child proof locks to put through cabinet door handles before we close the slides for travel. You may have to get inventive to protect cabinets and drawers from the power of hydraulic slides, but I always check things before moving the slide in either direction. The smallest thing can cause trouble....a flip flop, plastic garbage can, dog bed,....for example.
Good luck, and enjoy your trips!
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
Davidg is offline   Reply With Quote
Old 03-26-2016, 10:22 AM   #7
ov845's Avatar
X2 Our TT has 2 slides, both extend out on the same side. We always add an extra Lego block to compensate for the slides, then with the slides out, recheck that its level.
Happy Camping!
2012 Ram 1500 Crew Cab 5'7" Bed
Engine 5.7L Gear 3.92
Airlift 1000
2015 2809W Windjammer
Husky Centerline WDH
ov845 is offline   Reply With Quote
Old 03-26-2016, 10:50 AM   #8
The amount of "Blockage" needed to "bring to level every time" is dependent on a Level Site,some Sites require Lots of Blockage! Youroo!!
ID:	102883   Click image for larger version
Name:	2014 fall 1127.jpg
Old 03-26-2016, 11:14 AM   #9
Left Coast
Look closely at the latches on your doors and drawers.....they are adjustable
Old 03-26-2016, 12:23 PM   #10
Bob, the door latches are indeed adjustable, but only for the latch point,...so the door appears closed,....but not adjustable for latching force. That would require bending the metal insert, which might lead to other problems. The drawers, I'm not sure about, but I've never had a camper that potholes wouldn't open a drawer. At least on Louisiana roads...
slide
