Old 11-03-2015, 01:36 PM   #11
We have a V-lite 26 FKSS. I put a 2 way adjustabel level on the tounge just ahead of the jack. I adjusted the bubbles off so with the slides in it appears level. When the slides go out the bubbles will be off, but the unit is leveled. Took a couple of adjustments to get it just right.
masterglenn72 is offline   Reply With Quote
Old 11-03-2015, 01:46 PM   #12
redcloud1's Avatar
I also shoot for somewhere between a half inch to an inch on the slide side, this will usually bring me almost level. They also put for screw jacks under the frame to help stabilize the trailer along with x chocks.
redcloud1 is offline   Reply With Quote
Old 11-04-2015, 06:36 PM   #13
Dabmeb's Avatar
We always set the slide side 1 inch high when setting up.
Dabmeb is offline   Reply With Quote
Old 11-04-2015, 06:57 PM   #14
You must take into consideration that all the Posts that give a Specific thickness to gain Level are starting on a Level surface, most C/G pads are NOT level! Youroo!!
Old 11-05-2015, 05:01 AM   #15
Alleged curmudgeon
Vern's Avatar
We err (slightly) high on the slide side with our 3008W, so that our heads are not downhill when sleeping.
Lee
2013 Windjammer 3008W
2006 Chevy Silverado 2500HD 6.0L w/Equalizer 4
Nights camped: 2012 (29); 2013 (26); 2014 (40); 2015 (43); 2016 (35); 2017 (34)
Vern is offline   Reply With Quote
Old 11-05-2015, 08:14 AM   #16
Klbrown53's Avatar
Leveling a Winjammer 3008W
It is an estimate and varies every we set up most likely due to what some else said about pads not being perfectly level. I have been getting ours pretty much spot on using the estimation method until this week and I deemed it level enough based on the bubble and unhooked. When the slides came out I was way off. I just slept with my head downhill......
Klbrown53 is offline   Reply With Quote
Old 11-06-2015, 11:32 AM   #17
Thanks to all that helped with the leveling problem. Now we are still not quite comfortable with the occasional swaying.
jnkirkland is offline   Reply With Quote
Old 11-06-2015, 11:47 AM   #18
Georgia Frog Rally 2018
aceinspp's Avatar
I had the V-Lite version of your camper and very early on had noticed the tt out of level after extending slides. I always would check the level of the camper prior to any set up and most times trailer was not level on slide out side. I started using a 2x6 board placed on slide out side. Also I would extend the stabilization jacks before putting the slides out. Never had an issue after with cross level from then on. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
aceinspp is online now   Reply With Quote
Old 12-02-2015, 06:27 PM   #19
Funny you bring that up. I put two levels on mine one for parking it and the other for when the sides are extended. This works for me. I also, for me, notice when you walk in it it tilts somewhat. So I tried to use the leveling jacks as high as I can using the giant Lego blocks. Maybe someone else has a better idea. It this is confusing I retry to explain
Old 12-03-2015, 01:13 PM   #20
leveling 3008
side to side 1". do not use stabilizers to lift trailer. bounce is from torsion axles, (on my trailer)
2OLDDIGGERS is offline   Reply With Quote
3008w, leveling
