Old 12-03-2015, 01:26 PM   #21
caper's Avatar
I use the bubble level and if it is out by 1 inch on slide side I will add 2 inches to allow for slide. If the other side is high by and inch I will leave the trailer as is and just lower the stabilizer jacks. I also have scissor jacks beside my axles this helps to eliminate the bounce in the trailer.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 02-10-2016, 04:42 PM   #22
Dazed & Confused
M&K Hoffman's Avatar
Originally Posted by Vern View Post
We also shoot for 1 1/2" high on the street side (opposite the door) before we deploy the slides on our 3008W.
I agree, 1-1/2" works well for me, also a 3008W.
~Mike & Kim~
2014 Rockwood Windjammer 3008W Diamond Package
2012 Toyota Tundra Doublecab 5.7 4WD
M&K Hoffman is offline   Reply With Quote
Old 02-12-2016, 05:05 AM   #23
We also have a 3008 and I put 2 levels on it one for storage the other for when the slides are in use. Your right about 1 .5 in. It's the hardest towing vehicle I've had. Only used it for one trip. Still a lot of things to work out. I like the unit but I wouldn't buy it again
jnkirkland is offline   Reply With Quote
Old 02-12-2016, 05:28 AM   #24
What do you mean " Hardest towing vehicle I've had"? Youroo!!
Old 02-12-2016, 06:26 AM   #25
redcloud1's Avatar
I'd also like to know why you say it's the hardest towing vehicle you've had. I have a Windjammer 30008 and it tows great. And I tow it with a Silverado 1500, with weight distribution hitch and duel sway bars.
redcloud1 is offline   Reply With Quote
Old 02-12-2016, 07:00 AM   #26
Hardest towing.* Sway, bucking.** The trailer was bought new last yr.* My tow vehicle is a new Ford 150 ecoboost. Tow limit about 12000 lbs.* I had two smaller trailers 30 yrs ago a few boats and towed alot**** but this is starting over.* Any advise is welcomed
Old 02-12-2016, 07:15 AM   #27
Two Quick Q's, what tires are on your TV and the TT? Youroo!!
Old 02-12-2016, 07:18 AM   #28
RSchleder's Avatar
Not sure what brand of WDH you own, or even if you have one. We need to know some details about your towing setup in order to provide any info/assistance.
Chances are, if you have a quality WDH, it is not setup correctly. If your using the setup made by the dealer, chances are even higher that it is not setup correctly. Most of us have had to reset up/adjust our WDH to operate properly. Give some info here and I'm sure this forum can help you!
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 02-12-2016, 07:27 AM   #29
The hitch is a equalizer with 4 point sway control. Tires I don't know off hand. Like I said earlier is new 2016. I will have to get back as it warms up some. It's in stowage. Thanks for any information. One thing I'm in Germantown MD do anyone know where to have this weighed. I need to know if the distribution of weight is correct
Old 02-12-2016, 07:52 AM   #30
nomad297's Avatar
The closest Cat Scale to you is in Jessup.
You need to lose the grocery getter P Metric tires on your F-150 and replace them with LT tires. Then get your weight distribution setup properly.
My Windjammer tows like a dream. I believe I have covered what your problems are.
Bruce
nomad297 is online now   Reply With Quote
3008w, leveling
