Old 08-27-2018, 01:45 PM   #1
AKA: 'tiredTeacher
awellis3's Avatar
Levelling issues with torsion bar axles
I've learned to level my trailer a bubble high on the slide side so when the slide is deployed, it will settle level. Stabs make no difference, of course.
Anyone else with this suspension notice the settling condition?
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 08-27-2018, 02:49 PM   #2
That’s the way it works for me too.
New to it all
2016 Tundra and 2013 Rockwood 8310SS
GSPguy is offline   Reply With Quote
Old 08-27-2018, 02:57 PM   #3
llr
Same hear, I doubt it it has anything to do with the axle type. My last TT had spring axles and didn't tip as much however it only had one small slide
2024 Artic Fox 3018 5th Wheel
Grand Design 2800BH TT 2021 - for sale
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2024 F350 DRW - on order
Prior TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload
llr is offline   Reply With Quote
Old 08-27-2018, 04:26 PM   #4
Any axle with any kind of "spring," be it a real leaf spring or a torsion spring, is going to do this. It's the nature of the beast.
2011 Traverse LT, 3.6L, FWD
Old 08-27-2018, 04:47 PM   #5
Georgia Rally Coordinator
aceinspp's Avatar
X 2 I have two slides on one side and one on the other and at times I still need raise the side with two slides. I have found also if the tt is level and need no blocks I can put down stabilizer jacks first before putting out slide does work at times also. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Old 08-28-2018, 03:46 PM   #6
AKA: 'tiredTeacher
awellis3's Avatar
My first TT had no slides so this caught me unawares. Thanks for the reports.
Wright and Penny
Richmond, Va.
Old 08-28-2018, 05:13 PM   #7
cmac7203's Avatar
I’ve got three slides, one large one on each side and a little one on one side. Think I’ll need to bubble up? Of course I will test it, just curious.
2019 Rockwood 2707WS
2009 Ram 2500 5.7/3:73
cmac7203 is offline   Reply With Quote
Old 08-28-2018, 05:58 PM   #8
You'll never know until you do it. Every rig is different.
Old 09-03-2018, 08:29 PM   #9
LEVEL
I do the same w/ 27vsl Flagstaff. It has both slides on the same side. Do not think the axels make a difference.
Tundra 2014 is offline   Reply With Quote
Old 09-03-2018, 08:47 PM   #10
I do the same. Both slides on the same side. I set it about 3/4 inch high on that side. When the slides are run out, the weight extending out and hanging off that side, settles/compresses the springs on that side more.
I don't drop the stabilizers, until the slide have been run out.
katkt is offline   Reply With Quote
axle
