Old 11-21-2015, 03:31 PM   #1
Lift kit for 2012 8289
Because my pickup sits high in the pin area and the back axle on the trailer is carrying more than it's share of the load, I set out to buy a Dexter Lift Kit. The problem I ran into was that with the #10 kit, the hole spacing was 8" compared with my hole spacing of 6-1/4". In checking the numbered 9, 10, 11 and 12 kits, none match up with what I need. I can't imagine I'm the first one to experience this problem but haven't found any other threads related.
robertew is offline   Reply With Quote
Old 11-21-2015, 05:51 PM   #2
mstell2's Avatar
You probably don't have Dexter axles. Mine doesn't, had to call forest river to buy the lift kit.
mstell2 is offline   Reply With Quote
Old 11-21-2015, 07:29 PM   #3
You are correct. It has AL-KO axles. It's been more work adapting the Dexter kit that it would have been to have made the kit from scratch. I had read many threads where the Dexter kit was referenced so didn't have a thought but what it would work. In retrospect, if I'd checked out the hole spacing and bolt diameter, I'd have known.
Thanks for the response.
Old 11-22-2015, 10:57 AM   #4
mstell2's Avatar
The kit for alko is same price
Old 11-22-2015, 11:27 AM   #5
Witch Doctor's Avatar
What is your TV?
Coachmen M/H
Concord
2018 / 300 DSC
Old 11-22-2015, 01:41 PM   #6
Jack350's Avatar
I raised my 5th wheel two inches with the Correct Track kit. This also allows for axle adjustments if needed for alignment. I have dexter axles but this kit could work for your axles. I am very happy with the results and quality of this kit.
2017 Open Range RES 347, 2022 F 450 4X4 LWB 6.7.
Hayes Autoformer, Moryde SRE 4000, Sailun Tires, Andersen Aluminum hitch.
Jack350 is offline   Reply With Quote
Old 11-22-2015, 03:17 PM   #7
frozen's Avatar
Rockwood uses torsion suspension. Correct Track is for leaf springs, right?
frozen is offline   Reply With Quote
Old 11-22-2015, 04:55 PM   #8
Left Coast
Lower tv
Old 11-22-2015, 05:25 PM   #9
gljurczyk I don't know what "TV" that you ask, stands for.
Old 11-22-2015, 05:43 PM   #10
Jack350's Avatar
Correct track is for leaf spring only. Did not know you had torsion suspension.
Old 11-22-2015, 05:51 PM   #11
Thanks for the suggestion. I'd not opt for the torsion suspension after this experience as it allows very little travel, and thus, the coach has a rough ride.
Old 11-23-2015, 03:17 AM   #12
It stands for Tow Vehicle. I know the newer truck beds are higher. I'm changing out a hitch today. taking out of a 2004 F-250 and putting it in a 2007 F-250 the bed is about 3" higher, I think that they can still drop the Huskey down a notch to make me level.
Coachmen M/H
Concord
2018 / 300 DSC
Old 11-23-2015, 07:32 AM   #13
Thanks for the explanation. I tow with a 2013 F-150 4X4. I've removed the raising blocks from the pickup axle which lowered the tailgate by two inches and brought the box clearance as low as my hilly driveway will permit, but even with all that, I'm still not close to level.
Old 11-23-2015, 07:39 AM   #14
Jack350's Avatar
I have a 2000 F350 4x4 CC SRW and plan to get a 2017 Ford truck with the exact same specs as the 2000. If you have made this switch to a 2015 or 16, what is the difference in height. Thanks
Old 11-23-2015, 08:10 AM   #15
To the O/P, Contact Member B&B he had a Lift Kit installed on his Rockwood! Youroo!!
Old 11-23-2015, 08:25 AM   #16
leefl's Avatar
I'm a little confused why the need for the height adjustment, unless your truck is raised above standard height.
I have a (mostly stock) 2016 F-250 which has the bed about 2" higher than the 2015 F-150, and with the Reese Titan hitch, which does have some adjustment, can tow or 2015 Rockwood fiver level (as best as I can tell using a spirit level), with over 6" clearance over the bed rails.
Actually I guess that's maybe due to the pin weight, because our fiver does have a heavier pin weight than any other "ultra light" I've seen, and thus probably drops the rear of the truck more than many others would, so a fiver with a lighter pin weight may ride higher at the front
2015 Rockwood Signature UltraLite 8281WS
2016 Ford F-250 Lariat CrewCab, 4x4, 6.2L V8
leefl is offline   Reply With Quote
Old 11-23-2015, 11:03 AM   #17
My pickup is a 4X4. It is actually lower, by two inches because of removing the Raising blocks Four installed between the bottom of the springs and top of the axle flange. I have a bed cover that raises the height by maybe an inch and a half. With maybe less than the 6" clearance, you mentioned, the trailer is high in the front, thus loading it's rear axle more than it's front axle and adding additional pin weight to the pickup. The Dexter lift kit will add 2.625" to the trailer. That will help level it out.
