Old 07-15-2010, 11:25 AM   #1
Nights Camped in 2010 - 2
Light on front left of trailer
I have a small 12VDC light on the lower left front of my 2604 that is not working. How can tell if it is the switch? The bulb looks fine. Could it be wired into the towing harness? Used for pitching, maybe? Thanks,
George Kelly
2011 Rockwood Ultra Light 2604
Dodge RAM 1500 Larime 4x4, 5.7 HEMI
Nights Camped 2010 = 18
Nights Camped 2011 = 15
sailingsuppo46 is offline   Reply With Quote
Old 07-15-2010, 11:44 AM   #2
donjuanss's Avatar
I had a problem with mine and I just took a jumper wire and bypassed the switch to see if it was the wire the bulb or the switch. Mine was the switch so I bought a new light and replaced it
U.S. Army Retired Desert Shield/Storm Vet
2014 Silverado Crew Cab
2009 28ft Flagstaff V-Lite
1996 Impala SS 1972 Chevelle SS
donjuanss is offline   Reply With Quote
Old 07-15-2010, 12:02 PM   #3
Thanks. I really think it is the switch. If that is my only warranty problem, I will be very happy. Cheers,
George Kelly
Old 07-15-2010, 12:25 PM   #4
I should have asked in my last post. If the switch is bad, should I disconnect it?
George Kelly
Old 07-16-2010, 01:50 PM   #5
Iggy's Avatar
No you don't have to disconnect the switch if it is bad. If it doesn't work it will not casue anything unsafe. It just the cheap internal parts won't come together to complete the circuit.
I had one go bad years ago and I took it out and some wood chips were messing it up. Shook it a few times and all was working again.
You never mentioned what actually was bad in your power cord on your first trip out. Did they just replace the whole cable and all was working?
Have a great day.
Iggy in the cool part of Arizona
Old 07-16-2010, 04:12 PM   #6
Iggy,
Thanks. The switch is bad. The light is in a bad spot becuse it collects road grime. Not being sealed, I am sure that it collects water in a good pour on the road. It is under warranty.
The dealer swapped out the camp. The female end was bad. New cord fixed the problem. Very glad I had the opportunity to op check before leaving.
We are in our site and things are go to go so far. Thanks
George Kelly
Old 07-16-2010, 08:28 PM   #7
You can always check the bulb with a meter, if you have continuity the bulb is good or just replace it. The bulbs are cheap at Wal-Mart.
Old 07-17-2010, 09:05 AM   #8
RW06,
Switch is bad. Jumped across the connections and bulb lite. First thing on the list for the dealer. I did find the RV section at my local Wal-Mart and it cost me some bucks. I will definitely use them to get things in the future. Thanks,
George Kelly
Old 07-19-2010, 07:04 AM   #9
tomjsas's Avatar
Mine is the same...taking the trailer in for warranty work next week and that is on the list. You can see where moisture has gotten in...most likely when driving in the rain and corroded the connection.
Tom
Pull-Rite 16K Super 5th
2014 Rockwood Signature Ultra-Lite 8289WS
2011 Chevy 2500HD - DuraMax (Just over 5000 miles now!)
Nights camped in 2014 - 21
tomjsas is offline   Reply With Quote
Old 07-19-2010, 07:10 AM   #10
Tom,
Exactly the same on mine. Not a well thought out design. I too will be heading in to the dealer this week for some work. By chance, do you any issues with you slide roof? I noticed on the ends that the rubber cover is bubbled up ...loose like they cut it to long. Thanks,
George Kelly
rockwood
