Old 09-02-2014, 03:08 PM   #1
Lights, I give up...
I'd like to change the bulbs in the lights above our bathroom sink but I can't seem to figure out how to get at the bulbs...
I don't want to break the cover, I think it's glass.
Here's a picture of the lights, from the outside!
cachencouple is offline   Reply With Quote
Old 09-02-2014, 03:15 PM   #2
Yes they are glass covers, they come off with a counter clock wise turn( while looking up at light) should be LED bulbs depending on year of unit.
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 09-02-2014, 03:16 PM   #3
heavynlori's Avatar
I think those frosted covers unscrew from the ceiling
heavynlori is offline   Reply With Quote
Old 09-02-2014, 04:03 PM   #4
Got it!!
thanks for the replies... armed with your suggestions I went out and fought with the lights again. This time, I won!!
Turns out they don't turn, that is to say they don't unscrew, they 'just' pull off. There are three little clips in the base that holds the glass piece on and you have to pull down to remove. I sort of turned and pulled at the same time as well has finding a point on the cover that seemed to 'want' to come off.
Here are some pictures of the lamp apart.
Next thing is to find some LEDs to replace these bulbs. I'm not sure if they are just simple incandescent or halogen bulbs. And I'm not sure what LED would replace them... any suggestions?
ID:	62003   Click image for larger version
ID:	62004   Click image for larger version
Old 09-04-2014, 01:59 PM   #5
lickem66's Avatar
I went to M4 Products and searched for my bulb types and it showed the LED equivalents.
2016 FR3 28DS
Past 2012 Forest River Rockwood 2104.
2016 Nights Camped = 34, 2015 = 21, 2014 = 22, 2013 = 24
lickem66 is offline   Reply With Quote
Old 09-04-2014, 10:01 PM   #6
Your light fixture is a little different then mine, but you're looking for a G4 (pins are 4 mm apart) bipin LED light bulb to replace the halogen bulb. The original may be 10w, 15w or 20w bulb and put out approx 140,210,280 lumens respectfully so it's not that bright.
Something like this Mudder® 2pcs G4 Base DC/AC 12-24V 6W COB SMD 220-260lm LED Bright Warm White Light Spotlight Bulbs - - Amazon.com would be a great replacement.
2015 Keystone Raptor 425TS full body paint
TV 2015 RAM 3500 MC 4x4 DRW w/ AC69RC HD Trans
Pullrite Superglide 2300 24k w/ OE adapter 25k
cobiker is offline   Reply With Quote
light
