Old 09-24-2016, 06:45 PM   #21
padcarroll
I will use liquid from now on. I occasionally have to use a macerator pump at certain places we stay. I was using drop ins that are supposed to dissolve in water. The last time I used the pump I blew a fuse. This had never occurred before. I replaced the fuse and noticed the pump was real hot. I pulled the pump off and found it was clogged with plastic and there were undissolved packets left in the drain tee. I disassembled the pump and removed all the plastic wrapped around the impeller. I had one packet left so I dropped it in a bucket of water and the plastic did not dissolve in 3 days.
Dave and Pam Carroll
Callie - 8 yo chihuahua/yorky mix
2014 Legacy SR300 340BH
2013 Chevy Sonic Toad
Full-timing since January 2016
padcarroll is offline   Reply With Quote
Old 09-24-2016, 06:48 PM   #22
woodyrock1's Avatar
Wow, I never heard of that happening before but I believe you. Thank you for that post, I will stay away from drop ins.
2005 Ram 3500 Cummins Dually
2014 8280WS Rockwood Signature Ultra Lite
woodyrock1 is offline   Reply With Quote
Old 09-24-2016, 07:34 PM   #23
Back On The Go
Same as Ford Idaho; the Blue Stuff as we call it. 16 yr experience and tried many different ones. 5 minutes later: I lied. Just checked and it is Thedford Aqua Kem I think it's called. Really good stuff and you can get a larger container of it and refill your little 4 oz. ones to save money if you're into saving money like I am.
2016 Georgetown 270S
2013 Ford C-Max Hybrid
2 Janis Hybrid Bicycles
Not too serious about anything except what affects health and happiness.
salwolfe is offline   Reply With Quote
Old 09-24-2016, 07:52 PM   #24
Originally Posted by woodyrock1 View Post
Dalford, how do you like the Bluestreak system? I was looking into it as it looks interesting. What is making you thinking about going back?
I like the fact that it is automatic in that it puts in a small amount of chemical with each flush. It also has a small hint of a baby powder smell. I was concerned before I used it that the whole RV would have a baby powder smell but it doesn't, only in the bathroom.
I was using Odorlos and have used it for over 10 years but it just seemed like I was wasting a lot. I used the pouches and they would stick together in a humid environment (Florida). Also, would go for a short trip and would have to dump and add another whole pouch each time I flushed the tank. Plus it can be messy if you get the pouches you need to open.
I have had the system installed for a few months but am having a sewer smell in RV. I think my holding tank is bad and it is at the dealer right now for repair. Once that is done I can give a better review. I don't want to go back to pouches or measured liquids if I can.
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
dalford is online now   Reply With Quote
Old 09-24-2016, 07:54 PM   #25
Dave Lyon's Avatar
Geo method and odorlos. Works for me.
Dave Lyon is offline   Reply With Quote
Old 09-24-2016, 07:56 PM   #26
I know for a fact Odorlos make a dissolvable pouch and a non-dissolvable pouch that has to be opened with a pair of scissors. Make sure you had the dissolvable pouch but since you went to liquid only it is a non-issue for you but a warning to other campers.
2016 Siverback 33IK
Old 09-24-2016, 08:19 PM   #27
sgtlm17's Avatar
I've used the blue streak system for 15 years. Love it! Completely automatic and the bowl water is blue.
2016 Forester GTS 2801QSF
sgtlm17 is online now   Reply With Quote
Old 09-24-2016, 08:33 PM   #28
Decon Blue's Avatar
I been a Full time RVer for almost 20 years now, tried them all and for the last few years I have just added Dawn dish washing liquid to my black tank. I buy the 9oz. bottles, add 1/2 bottle after each dump and the other 1/2 when tank is about 1/2 full. Cost is bout a dollar a bottle and yet to have smell or problems. FWIW I always fill my tank and dump it out each time I dump to aid in cleaning out any debris.
Retired and loving it. Still looking for that perfect high.
Decon Blue is offline   Reply With Quote
Old 09-25-2016, 11:28 AM   #29
Liquid.
Rollingdunder1 is offline   Reply With Quote
Old 09-25-2016, 11:34 AM   #30
asquared's Avatar
We use the geo method. Works well.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
