Old 03-27-2010, 08:43 PM   #1
Location of drain valves
Hi,
Anyone know where the low point drains for hot and cold water are located on a 2010 Rockwood 2604SS?
Colorado High is offline   Reply With Quote
Old 03-27-2010, 11:59 PM   #2
look underneath the camper should be a red and blue line with a cap on them also i think someone on here said under the shower but i may be wrong
2008 8296SS Rockwood Signature Ultralite
2002 Silverado 2500HD extended cab
chevy02 is offline   Reply With Quote
Old 03-28-2010, 03:07 PM   #3
Arn
Arn
Look up underneath where your dump valve is. Just pull the "T" at the end of them to open.
Arn is offline   Reply With Quote
Old 03-28-2010, 07:26 PM   #4
Mine are under the city water hook up area which is next to the in side shower, but the valves are in side of the camper under the entertainment center behined the lower cabinet doors and mine are not color coded.
Old 03-28-2010, 09:31 PM   #5
dont pull the T that is your black and grey tanks dump valve not your low point drains
Old 03-29-2010, 07:51 AM   #6
Hipshot's Avatar
On my 2010 2604SS the low point drains are up under the left side skirting and about 8-12 inches forward of the sewer connection. If you lay down and look up in this area you will see them. Once you know where they are it easy to reach under the skirting and find them. My low point drains do have red and blue T handles on the ends. The low point drain T handles are quite small 3/4 inch ?, not to be confused with the black/grey tank dump valves 1 1/2 to 2 inches and black. Hope this clarifies.
2008 Silverado 1500 LTZ 4X4
Great Wife and Idiot Yorkie
True Friends are like diamonds, precious and rare.
False ones like autumn leaves found everywhere
Hipshot is offline   Reply With Quote
Old 03-29-2010, 01:14 PM   #7
Smile Location of Drain Valves
Wow - thanks everyone for the answers! I'm sure I can find them now and will open them before the next freeze.
Rockwood 2604SS
Old 03-29-2010, 05:24 PM   #8
Arn
Arn
I'm hoping he understood to look up underneath. Could be disgusting otherwise.
rockwood
