Old 12-16-2017, 01:26 AM   #21
MadDog2020's Avatar
Manual Slide Crank
I was told that if you need to manual crank the slide you have to take the panels off at the bottom of the cabinets on the slide side, inside the trailer. I was also told there is so little room to turn the crank that your knuckles get a work out. I haven’t had time to check that out but I intend to.
MadDog2020 is offline   Reply With Quote
Old 12-16-2017, 10:24 AM   #22
Thanks MadDog2020. We'll also take a look at that space under the cabinet when the weather warms up a bit. Not fun to spend time in the trailer when the temps are too chilly.
Cathleen
2017 Rockwood Mini Lite 2503S
2012 F-150 Ecoboost
Cathleen is offline   Reply With Quote
cat, location, manual, slide, slide out
