Originally Posted by Powadeer
This year I purchased a 2012 Rockwood Signature Ultralite 8317RKSS. So far the camper has treated me well. I am in the process of winterizing it and need advice. Does anyone know where the water pump is located? The dealership told me to look under the entertainment center, but I don't see it. Also, when by-passing the hot water heater do I need to turn any switched beyond the hot and cold water switches coming out the back of the heater?
In our 8315BSS SUL the water pump is located in the bathroom area, in a small cabinet under the tall storage cabinet that is beside the sink. The access door has the normal two hinges on one side and one hinge on the opposite side. Your trailer likely has something similar. You will have to remove the screws on the single side hinge to open the access door.
...VTX-Al
