Old 01-13-2007, 09:25 PM   #1
Location of waterpur filter on 8287ss
My new 8287ss fifth wheel had been winterized when delivered in December. We are planning a trip in the next few weeks and I want to flush the water system and instal the water filter. Unfortunately, the dealer didn't show me where the filter holder was and I can't find it without taking off some panels. Before I do that does anyone know where I can find the filter receptical. Also, should I take off the panel in front of the water heater to get to the bypass values?
Gpsagent is offline   Reply With Quote
Old 01-14-2007, 12:41 PM   #2
milzat's Avatar
Water filter holder(canister) should be very near the water pump, where ever that may be.
I removed the false panel in front of the water heater the day I brought my TT home. Allows for more storage room.
milzat is offline   Reply With Quote
Old 01-14-2007, 02:04 PM   #3
MRimmer's Avatar
Mine is under the closet and behind the toilet in the restroom and almost impossible to get to. I have to remove the drawer just to see it.
Mike
MRimmer is offline   Reply With Quote
Old 01-15-2007, 10:41 PM   #4
Thanks for the tips. I will check the panel under the bathroom sink. I know that is where the water pump is. Milzat, I assume it isn't a problem to place items next to the water heater once the panels are removed. I know that on our last trailer the water heater was not covered and we stored things right beside it. Are the panels just for looks on these trailers?
Old 01-16-2007, 01:03 PM   #5
milzat's Avatar
Gpsagent,
I feel the false walls(panels) are mostly for looks. I try to remove, or at least move-back the panels as much as I can. This allows for more storage space/access.
I've have no issues with storing things next to the Water Heater.
Old 01-17-2007, 11:25 PM   #6
my filter is not very far from the city water inlet.
2013 flagstaff 831flss diamond package 2014 gmc sierra 3500hd cc 4x4 sb 6.0 4.10 gears, 2000 gmc 4+4 2500hd 6.0 4.10 gears equl-i-zer jorden 2020
farmermark is offline   Reply With Quote
Old 09-27-2007, 05:07 AM   #7
I have a rockwood 8314SS model, my water filter is located under the tv and behind what looks like a cabinet door. This cabinet door has 3 hinges, two on one side and one in the middle but no door knob. You can open this door by removing the center hings. You may have a couple cabinets like this.
Old 09-27-2007, 06:42 AM   #8
RAC
Have you seen that the posts you're answering to were made last January?
RAC is offline   Reply With Quote
rockwood
