Old 04-10-2011, 03:54 PM   #1
DAISY BOYKIN's Avatar
Look at your 8285ws axles ??
Would someone that has a Rockwood 8285WS look at you mounting of the axles to the frame (front and rear axles) of the RV where they are bolted on. See if you have a space on the front of the axles where they are bolted to the frame. See the picture posted ?
I have a email off to Rockwood/ Forest River asking if this is normal. I just noticed this this morning and email was sent today.
My 8285 WS is new, was picked up Jan 27, 2011.
Name:	AXLES MOUNTING 001.jpg
ID:	5223   Click image for larger version
Name:	AXLES MOUNTING 002.jpg
ID:	5224   Click image for larger version
Name:	AXLES MOUNTING 003.jpg
ID:	5225   Click image for larger version
Name:	AXLES MOUNTING 004.jpg
ID:	5226   Click image for larger version
Name:	AXLES MOUNTING 005.jpg
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
BOLIY PRO 3600SI GEN
DAYS CAMPED 2016 74 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 04-10-2011, 03:57 PM   #2
PART TWO of pictures.
Part two of the axles pictures.
Name:	AXLES MOUNTING 006.jpg
ID:	5228   Click image for larger version
Name:	AXLES MOUNTING 007.jpg
ID:	5229   Click image for larger version
Name:	AXLES MOUNTING 008.jpg
ID:	5230   Click image for larger version
Name:	AXLES MOUNTING 009.jpg
ID:	5231   Click image for larger version
Name:	AXLES MOUNTING 010.jpg
Old 04-10-2011, 04:05 PM   #3
sherdep's Avatar
Sorry I cant help with you question
wow - almost looks like the plate is bending as well from the pictures (Picture #2) - you would think it would be solid against the perch instead of sitting off of it - it does look like if you loosen the bolt it will slide and put the perch and the frame to a touching position.
Also would think there would be a flat washer on the bolt head side as well which doesnt appear to be one there either - just my observation
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 04-10-2011, 04:19 PM   #4
Strange about the space.
Both axles have the same space as if they were adjusted for the space.
Will see if Rockwood has a answer.
Old 04-10-2011, 06:07 PM   #5
backin15's Avatar
I understand this is not an uncommon problem. If you search this forum there is a thread on how to fix it. You can see in your pics one of the holes is elongated and you can see the indentation in the paint where the washer used to be. If I remember right you need to loosen the bolt and jack the axel plate back into position then retighten the bolt. In the thread there is a permanent fix, it involves drilling a new hole and installing an additional bolt so it can't shift again.
backin15 is offline   Reply With Quote
Old 04-10-2011, 06:33 PM   #6
axels
Thats worse than my 2011 2304s.You need to loosen the bolts jack the axels up and put bolts up threw the frame.Thats what iam doing.
4runner is offline   Reply With Quote
Old 04-10-2011, 06:42 PM   #7
Check the thread called ;
How many bolts hold your axels on?
I posted there how I fixed the problem.
I hope you can follow it, as it is a little confusing.
If they all slipped, it isn't as bad if only one or two slip, as that places uneven loads on the axles and tires.
As far as I am concerned, it is pathetic how the factory mounts these, and they should be adding the extra bolts as I did.
Old 04-12-2011, 02:31 PM   #8
Hoo Dad's Avatar
I checked out my 8285WS axles and did not find the problem as seen in your pic's. Have you heard back from Forest River?
2011 Rockwood 8285 WS
2011 GMC 3500 HD 4X4, 6.0, 4.10, SRW
Hoo Dad is offline   Reply With Quote
Old 04-12-2011, 02:34 PM   #9
Hoo Dad, your axles may not have slipped yet, but it will happen one day. There is simply not enough clamping force to keep them in place.
Or do you have more than two bolts per axle flange?
Old 04-12-2011, 04:01 PM   #10
wfmdfm's Avatar
Same Issue
I have a 8528RKWS and checked an I have the same issue. I have used this maybe 150 miles since picking it up 3 weeks ago. I assume this would be repaired by the Dealer?? I will discuss it with them. I am not a welder but think I could have done a better job than whoever put this together. Its ahame to get under there and see all the rust and its brand new.
2011 Flagstaff 8528RKWS
2015 Toyota Tundra
wfmdfm is offline   Reply With Quote
axle
