Old 11-17-2015, 10:05 AM   #41
Appalachian Ed's Avatar
I just got off the phone with Forest River. I simply asked if they would buy the OEM tires and give me a credit towards better tires. The answer was interesting. He (very nice by the way) said FR does not recommend going to a higher LR tire. It adds extra weight to the axle (65 PSI vs 50-55 psi) that was not in the design consideration. As such they do not recommend doing so. He did say that if I did so (to a D LR) I would be okay as long as I understood this reduced the amount of load I can add.
He also must be familiar with this forum. He said I suspect you are hearing this on a forum on the internet and it makes a single blowout feel like a thousand of them. He does have a bit of a point there, however I do have a friend at church that has experienced blowouts on his trailer (not a FR) and that was the first thing he warned me about as well was to improve the tires.
In the end he said as long as I keep them inflated properly and don't "take 90 degree corners at 60" these tires should do fine.
He also said that when a customer experiences a blowout they try very hard to take care of the customer. However in his opinion most of them are caused by overloading the trailer and improper driving.
Comments?
Appalachian Ed is offline   Reply With Quote
Old 11-17-2015, 10:14 AM   #42
Witch Doctor's Avatar
Originally Posted by Appalachian Ed View Post
We are purchasing a 2015 (got a great deal I think at $13K under retail). It has the doors on the island facing away from the kitchen which I did find a bit awkward but not too big a deal. I was not smart enough to inspect the tires when we saw the trailer and said "we'll take it". I called our sales guy (whom I really like) and he said it came with C LR tires.
I am still concerned about the E tire pressure on these rims. Anyone have any expertise (experience) at running E rated tires at 65 pounds or higher pressure on the OEM rims? The E LR tires are recommended at 80 psi. Would I be better off sticking to D LR tires? I see a lot of folks are running E LR tires but I have not seen any discussion about that exceeding the rim psi spec's.
You do not need to go to "E" rated "D" rated is fine and then run them at 65 PSI full CP. I do not like running tires under the CP rating. A "D" rated Marathon at 65 lbs CP can carry like 2350 lbs were your "C" rated maxed out at 1795 lbs. You will be making a mistake going to "E" rated with those rims. The 1st year I went to Calf. and Oregon on the "C" rated. Had a blow out 6000 miles. Then I went to the D rated..... Why would you go to "E" rated then have to run them under inflated? That's even worst IMO. We all know that they are bad, but how bad is the question. I would spend the money on a TPMS get it installed and be on your way to the Golden State.
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
Old 11-17-2015, 04:31 PM   #43
5er_tom's Avatar
As I stated earlier, LR D tires are all you need. If you do end up with LR E, you can run them at 70psi as I did. No issues at 70psi for 25,000 miles.
Tom & Renée
Durham, NC
2015 Wildcat 295RSX
2012 Ford F-250, 4x4, 6.7 Liter Diesel
5er_tom is offline   Reply With Quote
Old 11-17-2015, 04:56 PM   #44
kcjoe1's Avatar
The tires Forest River puts on the 8289 are the bare minimum for an RV that size. I switched my tires over to E's and what a difference it made towing the RV. I don't have an RV that roams all over the road any longer. By the way, I changed tires because by the time we had our RV 13 months the rubber was starting to split on the factory tires and one of them started to leak. Piece of mind= new tires.
2017 Arctic Fox 27-5L
2014 Rockwood 8289WS Diamond Package (SOLD)
2008 Dodge Ram 2500 SLT 4X4, Anarchy Tuning
kcjoe1 is offline   Reply With Quote
Old 11-17-2015, 05:02 PM   #45
Hello Ed,
We just put our new 2015 82829WS into service about 2 months ago. Our 4 trips so far have been short drives and 3 or 4 nights each. We love the unit (our first). We recommend the second AC unit - you never know when the temps will take off. So far, the 5th wheel has been superb. No real problems. We did notice the plastic indentations near the top of the front nose cone. Haven't asked the dealer to fix just yet. Good luck in your new adventure!!
Brad Applegate
Southern Indiana
2015 Signature Ultra Lite 82890WS, Ford F-250 King Ranch
RedhawkCC is offline   Reply With Quote
Old 11-17-2015, 07:39 PM   #46
How about a winterization question. We want to use our new trailer this winter occasionally to have a little fun. I see temps here in SC are going to get lows in the upper 20's (mostly in the lower 30's for lows though) over the next couple of weeks. Probably pretty much like that all winter.
How do you handle winterization if the 5er sits 3-4 weeks between usages. Do I need to winterize and de-winterize for each trip?
Sounds painful.
Ed
2015 Rockwood 8289WS
2009 Ford F-250
Old 11-18-2015, 08:20 AM   #47
I'm not sure where the "recommended" 80 PSI came from. That may be specified on the tire but through other discussions, the tire pressure is to be determined by the tire load. There are charts for this. The recommended pressure on the label on cars or pickups doesn't correspond to the pressure on the tire but corresponds to the maximum weight on that axle. I've run my Load Range E at 65 PSI cold and covered many thousands of miles. This was an arbitrary decision on my part but haven't had any rim issues nor have I read of any on the forum.
robertew is offline   Reply With Quote
Old 11-18-2015, 08:30 AM   #48
B and B's Avatar
Honestly no matter how hard I searched I could not get a answer on the rim ratings. The Supplier lionshead could not say when contacted. Research on other sites showed no results. I run 60 psi on stock rims with D tires. E at 80psi I would concerned also the ride would shake the trailer to pieces.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 11-18-2015, 09:06 AM   #49
This discussion has caused me to look further. Looking at a tire pressure load chart-http://www.goodyearrvtires.com/pdfs/rv_inflation.pdf, for the ST225/75R-15 tire on my camper, shows that at 50 PSI the tire will carry 2150#. The individual axle rating on this camper is 4000 and weighing mine loaded, the heavier axle weight was 3800#. It looks like I can safely drop my pressures back to 50 PSI. Dropping the pressures is easy compared to resetting the monitor!
Old 11-18-2015, 09:27 AM   #50
Brain this is what I got from Lionhead, also good year inflation chart. read the last paragraph.
File Type: pdf Goodyear_Tire_Inflation___Load_Charts.pdf (274.9 KB, 39 views)
Coachmen M/H
Concord
2018 / 300 DSC
