Old 11-28-2019, 09:41 AM   #1
Looking for a modification to the plastic nuts on propane cover
Does anyone have suggestions for replacing the plastic nuts on access door of propane cover?
tls5150 is offline   Reply With Quote
Old 11-28-2019, 10:56 AM   #2
If you just need replacements:
https://www.amazon.com/Camco-40547-R.../dp/B00HJ6OPAO
If you want something different, I have no suggestions other than wing nuts.
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 11-28-2019, 12:21 PM   #3
Take the nuts off. Thread them on a long machine screw and use a bench grinder to remove all, or most, of the notches at the bottom that make them hard to turn.
Replace on cover and just run them down snug.
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 11-28-2019, 07:29 PM   #4
I used wing nuts.
Rockwood 2604WS
Ford F250 Diesel
Blue Ox Sway Pro
allenb12 is offline   Reply With Quote
Old 11-29-2019, 09:36 AM   #5
Thanks that’s what I was looking at, these get tight and very hard to loosen
Old 11-29-2019, 09:36 AM   #6
Thank you, good idea
Old 11-29-2019, 09:37 AM   #7
Originally Posted by allenb12 View Post
I used wing nuts.
Was considering wing nuts thank you
Old 11-29-2019, 09:54 AM   #8
People use the door? It is easier for me to just lift the entire cover and turn the valve.
2018 Rockwood 2109S
Sahall is offline   Reply With Quote
Old 11-29-2019, 10:10 AM   #9
gastan's Avatar
X2
2012 Rockwood MiniLite 2104
2007 GMC ECSB 2500HD Duramax
gastan is offline   Reply With Quote
Old 11-29-2019, 11:47 AM   #10
Yes I think it’s much more convenient to use the door than pulling cover off.
Old 11-29-2019, 11:55 AM   #11
Noob
I absolutely use the door. My cover is secured underneath with a bungy cord, requiring me to get on the ground to indo it. The screws are just two thumb screws - not exactly a challenge for me.
Flywithlloyd is offline   Reply With Quote
Old 11-29-2019, 02:03 PM   #12
X2. I've seen too many covers laying along the side of the road.
Old 12-02-2019, 10:00 AM   #13
Magnet -
2020 Rockwood Mini Lite 2109S
2017 GMC 2500HD Denali 6.6L
01tundra is offline   Reply With Quote
Old 12-02-2019, 10:09 AM   #14
After losing one access lid from our former TT, I simply drilled a small hole on the hinge side and loosely fastened a cable tie. That quick and discreet (matching color cable tie) loss solution didn’t solve the thumb screw issue, but prevented us from ever losing the lid again.
Brian
2020 Forest River Forester 3011DSF
Mr Brian is online now   Reply With Quote
Old 12-02-2019, 02:06 PM   #15
I was referencing my entire cover, not the lid. My cover has a "tab" with a hole in it on front and back bottom, so you can just use a small bungie cord or rope to tie it around the tank supports. Kind of like in this stock pic:
But you have a good idea for just the lid.
Old 12-02-2019, 09:10 PM   #16
The magnet is a great idea! Thank you
Old 12-03-2019, 12:43 AM   #17
Me too. I can have the whole cover off faster than opening that door.
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is online now   Reply With Quote
cat, cover, propane
