Old 06-17-2016, 10:16 PM   #1
Low point drain leak
I noticed a pinhole leak in my hot water low point drain. It's just above the cap and lightly spraying water into the undercarriage. There's a lot of caulking above it so I can't see how it's attached to the hot water line. Can this be replaced by a DIY type like me? I don't want to start carving caulk away now. I'm on a trip for a few more days. I've turned the water off and will only turn it on as needed to cut pressure from the lines (city connection). I didn't want to chance the leak getting bigger.
rick8671 is offline   Reply With Quote
Old 06-17-2016, 10:25 PM   #2
SeaDog's Avatar
easy fix cut the pipe at the leak and install a valve or a new cap
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 06-17-2016, 10:27 PM   #3
Thanks! I'll give that a shot when I get back!
drain, leak
