Old 05-24-2014, 09:02 PM   #1
Low point drains
Hi, The low point drains on my 2502s are drained by unscrewing black caps. I would like to put valves instead of the caps. They used a CPVC crimp to (pex) to male thread and cap. What kind of valve can I use instead of the cap. I would like to just screw on a valve instead of the cap. Any idea's ?
gserve is offline   Reply With Quote
Old 05-24-2014, 09:23 PM   #2
Ford Idaho's Avatar
Something like this should work.
Hayward PVC Ball Valve, Gray, One Piece, EPDM Seal, 1/2" Threaded | AmazonSupply.com
I'd go to Lowes or Home Depot.
Take the cap with you to make sure you get the right size
Old 05-24-2014, 09:44 PM   #3
onetonford's Avatar
This is what I did with mine got the parts from home depot and still have the caps on the out side for backup.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 05-25-2014, 03:59 AM   #4
cpaulsen's Avatar
I just removed the caps and screwed in some pvc ball valves from HD.
cpaulsen is offline   Reply With Quote
Old 05-25-2014, 05:24 AM   #5
Herk7769's Avatar
X2
HAM CALLSIGN - KC3FFW
Old 05-25-2014, 08:13 PM   #6
I did mine just like Herk7769.
CA62Mini is offline   Reply With Quote
Old 05-25-2014, 09:35 PM   #7
bubbles's Avatar
Originally Posted by Herk7769 View Post
X2
The caps are male. Is what you said, all you did. Just curious.
Old 05-25-2014, 10:23 PM   #8
onetonford's Avatar
I tried what herk did and it just leaks like crazy I tried to seal with tape no luck I tried with special pvc compound still leaked so went the route I went also the valves are protected from the elements. the fittings are a black plastic on mine and the caps have a sealing washer had some adapters made but was unable to find a suitable washer to work.
2011 25 RL Wildcat
Old 05-26-2014, 03:46 AM   #9
Herk7769's Avatar
Caps on; caps off (valves on).
ID:	53306   Click image for larger version
Old 05-26-2014, 06:51 AM   #10
bubbles's Avatar
I was just curious because the identical looking valves at my HD/LOWES only come with female ends (both ends). They do not carry such a valve (plastic) with a 1/2 inch male on one end. Thanks.
drain
