Old 04-09-2015, 07:11 AM   #1
Low water pressure when using pump in 8329SS
We have a new 8329 SS. When using city water, the pressure is fine, but when using the pump for on board water the pressure is unacceptable. Is there some adjustment or would it be bad to increase the pressure? Thanks for any help. Jim
Jim McCormick is offline   Reply With Quote
Old 04-09-2015, 07:17 AM   #2
Most RV pumps are (Fixed PSI)! Is it LOW with only (1) fixture on? Youroo!!
Old 04-09-2015, 07:24 AM   #3
TURBS's Avatar
Water filter plugged?
Mini screen near pump plugged?
Tap aerator plugged?
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "2 nights"
Old 04-09-2015, 07:29 AM   #4
Is the pump purged completely of air?, is there a fill tube for antifreeze that has an open valve?
2014 Windjammer 3025W Diamond 34.5 ft 8300 lbs.
2010 F150 SC XLT 4x4 5.4L, 3.55 gears 20" rims
12 k Equalizer WDH, Firestone Airbags, HD Bilsteins
TST 507RV TPMS
Zolin is offline   Reply With Quote
Old 04-09-2015, 07:35 AM   #5
Also, make certain you have adequate supply of water in your fresh water tank. Some tanks also have an outlet filter screwed into the coupling where the outlet of the tank attaches to the tube going to tank.
TST 507RV TPMS
Old 04-09-2015, 07:41 AM   #6
Some tanks also have an outlet filter screwed into the coupling where the outlet of the tank attaches to the tube going to tank.[/QUOTE]
I meant to say "where the outlet of the fresh water tank attaches to the supply line going to the pump"
TST 507RV TPMS
Old 04-09-2015, 07:41 AM   #7
Oh by the way,and Jim I like your (Anti-Gravity Dog Pic) in your Profile! Youroo!!
Old 04-09-2015, 08:21 AM   #8
DDC
DDC's Avatar
I had this problem on two different trailers but both ended up being the same, take the pump off and clean out the plastic pieces that it has picked up, when they drill into the tank they do not clean out the pieces and they eventually get sucked up.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 04-09-2015, 11:20 AM   #9
Rodney & Patty
Agree with DDC - I too have had this problem when the filter screen is hold construction debris - fine plastic shavings that prevent the system from pressurizing. Also however, if there is any antifreeze still in the system it will foam and froth under pressure and not build to pressure. The first thing would be, is the pump shutting down, meaning that it believes it has made pressure, or does it continue to run trying to build pressure? Two separate issues...
rdenslow is offline   Reply With Quote
Old 04-09-2015, 11:38 AM   #10
You can also increase the size of your pump. find the pump and on the side it will say how many gph. Then you can upgrade to a pump that has a greater gph. I did this and have the same pressure on pump or shore. Keep in mind that this will use your tank water faster.
j free is offline   Reply With Quote
pressure, pump, water
