Old 07-01-2015, 02:39 PM   #1
MikeInRaleigh's Avatar
LP Plumbing
I have an 8280 5th wheel with an LP problem. On the curb side is a tank and a regulator with automatic switchover. There is a pigtail that goes directly from that tank to the regulator. The driver side tank is connected to a flexible pipe that goes to the second input on the curbside switching regulator. However, on the driver side, there is also a red regulator in the line. The regulator on the curb side seems to be exactly the same where the curbside tank is connected as to where the driver side tank pipe comes in. So, why is there an extra regulator on the driver side tank? This matters because the regulator on the driver side is leaking through a small hole on the regulator itself. I assume the hole is there for atmospheric venting, but apparently the diaphram inside must have a hole in it. Since the regulator on the curb side seems to be an auto switching two stage regulator, why do I need the one on the driver side?
2010 Rockwood 8280WS Fifth Wheel
2013 F350 Crew Cab SRW, Standard Bed PS Diesel
Reese Airborne Pin Box, Reese 16K Manual Slider.
Camped 36 Days in 2012, 23 Days in 2013, 35 Days in 2014, 30 Days in 2015, 46 Days in 2016, 5 days in 2017.
MikeInRaleigh is offline   Reply With Quote
Old 07-01-2015, 06:21 PM   #2
camping baba's Avatar
I also have a 8280 . The regulator on the driver side is a high pressure regulator . It takes the tank pressure and reduce it to approx . 10lbs . The switch over regulator on the curb side is a dual stage regulator that takes tank pressure and the reduced pressure from the driver side down to approx . 11" of water colloum . You are correct that the regulator on the driver side has to be replaced . Good luck .
2013 Silverado extended cab 4x4 1500 Series
camping baba is offline   Reply With Quote
Old 07-01-2015, 07:01 PM   #3
Thanks, but I don't see the need for the driver side regulator, since the switchover regulator is two stage. What am I missing?
Old 07-01-2015, 07:12 PM   #4
The piping would have to be changed from the regulator on the driver's to the change over regulator so that you would not have high pressure gas going from one side to the other . Now the pressure is approx 10 lbs , without the regulator the pressure could be as high as 100lbs or higher .
Old 07-01-2015, 07:58 PM   #5
Ok. That makes sense. Now I just have to find a Stage 1 regulator. I'm ok for now just running on the one tank, as all I need is just to keep the fridge going on a 6 hour trip. I just turned off the driver side tank. Thanks for the help.
Old 07-01-2015, 08:20 PM   #6
So I guess this implies that the hose running from driver side to curb side isn't rated for 100 psi. I am surprised at that, as it looks just like the pigtail hose.
Old 07-02-2015, 02:54 AM   #7
Just a member
kandl's Avatar
Just a WAG but perhaps this is done because of the distance between the driver side cylinder and the changeover regulator on the passenger side cylinder?
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
Old 07-02-2015, 05:36 AM   #8
A store that sells grills or if your dealer is close enough that would work . Maybe the Internet .
Old 07-02-2015, 06:18 AM   #9
Left Coast
Fire place stores also
Old 07-02-2015, 06:28 AM   #10
Crockett's Avatar
When mfg first started the opposing side cylinders, they did just run a high pressure line accross. But there were several connections because they did away with rubber and plumbed hard line. These connections were prone to leakage due to high pressure. Then they came up with the 10 psi red reg...much safer and still supplies the 2 stage with adequate pressure. Sometimes those 2 stages will bleed back through. Verify with soap no leaks through the red reg vent before you use...
Crockett is offline   Reply With Quote
plumbing
