03-18-2013, 07:22 PM
#21
My experience tells me that a lube plate will not fit when the reese revolution is set up, unless you cut away a portion of it. I don't use anything with my reese revolution.
Terry/Bernadette Lily the Yorkie 2019 Dodge Ram Sport 1500 2019 FR Vibe 28RL
03-18-2013, 07:28 PM
#22
When we picked up our 5ver, they had a circular lube plate installed on a slider hitch and the Reese Revolution locked. Didn't like the set up at all with the banging on take off and stopping. Went back the next day and they activated the Reese Revolution, took out the slider and put in a regular Reese 16k. No more banging. Gave the lube plate to a friend. BTW, it was a regular circular lube plate that had fingers that gripped the pin. No cutting required.
03-18-2013, 07:30 PM
#23
what I put on mine .
03-18-2013, 07:32 PM
#24
Exactly what I was trying to say. When I activated the Reese Rev, the locking plate would not fit with a lube plate in place unless I cut the lube plate away. I bet yours wouldn't fit either as you have the same setup as me.
03-18-2013, 07:42 PM
#25
Never even tried it, the dealer removed it. It would be absolutely useless.
03-18-2013, 07:43 PM
#26
Originally Posted by f1100turbo
That is exactly what I had that the dealer removed when he activated the Reese Revolution.
03-18-2013, 07:45 PM
#27
Denver, CO
These are 5 wheel hitches and we are worrying about scratching the PAINT? Really? Seriously? I'm having a hard time comprehending this. Thick steel plate, what's it gonna do rust or wear through?
2017 Fuse 23T
03-18-2013, 07:50 PM
#28
03-18-2013, 07:56 PM
#29
phat phrog stunt crew
i have the same deal turbs has on his. its plastic, costs about 15 bucks or so and keeps grease off of me (i seem to be a dirt magnet).
03-18-2013, 09:43 PM
#30
Owner/Operator
I'll get flamed for this, but get a real tow vehicle where you do not need to use the pivot of the Revolution, and your hitch will continue to look like this.
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
https://www.forestriverforums.com/for...ons-36212.html
03-18-2013, 09:45 PM
#31
My dw stopped buying me shirts that were anything but black.
03-19-2013, 10:23 AM
#32
Denver, CO
RodeoGeorge
That's very pretty.
2017 Fuse 23T
03-19-2013, 07:18 PM
#33
Senior Moment
Update : after checking with manufacturer they recommend grease on both sides of wedge, back side of pin, and on plate in front of pin. Mainly for ease of hooking up.
