Old 03-18-2013, 05:53 PM   #1
Senior Moment
rockport's Avatar
lube plates
First time 5th wheel owner and not sure if I need one or not. Using the Reese revolution pin box on my 8289ws. So should I be using a lube plate with this setup.
rockport is offline   Reply With Quote
Old 03-18-2013, 05:59 PM   #2
TURBS's Avatar
I have one on mine ....... I think its a matter of preference.
I went the first year without one and just put one on this winter to see if theres any difference.
I dont think you'll need one as your pin box does not pivot on your hitch but rather pivots back under the camper at the pin-box mount.
TURBS
Old 03-18-2013, 06:03 PM   #3
Senior Moment
rockport's Avatar
TURBS
That's what I was thinking. Wasn't sure if using one was important for just hooking up and un hooking.
Old 03-18-2013, 06:04 PM   #4
Fulltime family RVer
Use something - either grease or a plate. I scratched the paint up on mine by not using anything for a couple of months and about 3,000 miles towing.
ependydad is online now   Reply With Quote
Old 03-18-2013, 06:07 PM   #5
B47
Considering what they cost, I would recommend using one regardless of your hitch design. It would prevent any wear between your pin box and hitch plate when hooking/unhooking.
B47 is online now   Reply With Quote
Old 03-18-2013, 06:09 PM   #6
TURBS's Avatar
With a reese revolution the pin does not rotate on the hitch .....
Theres no need for a plate up there as nothing moves....
Name:	Reese Revolution.jpg
Old 03-18-2013, 06:15 PM   #7
B47
Isn't there still going to be contact between the pin box and plate when hooking/unhooking?
Old 03-18-2013, 06:17 PM   #8
TURBS's Avatar
There will be contact but since it doesn't spin on the 5th wheel hitch like a normal hitch what would be the reason for having a lube plate ?
Old 03-18-2013, 06:20 PM   #9
TURBS's Avatar
I see what your sayin B.
If anything else maybe just a thin coat of lube plate grease but I wouldn't see that there would be much wear since it just sits on the hitch and never moves.
Old 03-18-2013, 06:23 PM   #10
B47
Not to belabor this, but you did say there is contact. Can I assume the contact would be between the pin box bottom and the hitch plate top when hooking/unhooking. If so, then a lp would help minimize the contact.
Right ?
