Old 09-07-2015, 03:03 PM   #1
Maiden voyage on 2703ws
Spent ten nights in our 2016 2703ws. Loved the space and comfort in this TT. Disappointed in a couple of things. Had a water leak under the kitchen sink and water running out from under the bathroom sink. Air conditioner did not cool very well but blew enough air to blow Styrofoam from out of the vents. Should be a couple easy fixes, I hope.
firefighter73 is offline   Reply With Quote
Old 09-07-2015, 04:50 PM   #2
Can all be fixed; don't let these little things discourage you. When fixed you'll forget all about them, then you can just kick back & enjoy.
Papa GLS is offline   Reply With Quote
Old 09-07-2015, 05:09 PM   #3
They are discouraging but the TT is so nice and cozy it took our minds off of it.
Old 09-07-2015, 07:49 PM   #4
gooiebob's Avatar
If you remove the air conditioner frame inside, you can check to see if the Styrofoam is completely cut away for the ducts. Our wasn't. Also used some aluminum tape to seal the leaks in there.
Love ours, just have to fix what they can't get right at the factory.
2013 Rockwood Ultra Lite 2703ws
2014 Toyota Tundra 5.7
gooiebob is offline   Reply With Quote
Old 09-08-2015, 01:29 PM   #5
Western PA Happy Campers
Smile
X2 on Gooiebob. I have the Flagstaff clone of your Rockwood. Definitely have to pull the AC frame down on the inside and remove the stryofoam blocking the ducting. It was the same in ours. Also check the last vents in the BR and LR. They use that sprayfoam in the factory to close the duct at the end, but they don't do a real great job. You'll have to clean that up as well. Have fun with it. We love ours. DW and I can't wait till the fall when we can turn our inside fireplace on again.
2016 Flagstaff 27RLWS Emerald Ed.
2014 Chevy Silverado LT w/ 5.3
Reese 12,000lb hitch w/ Dual Cam Sway Control
lciaramitaro is offline   Reply With Quote
Old 09-08-2015, 01:44 PM   #6
Georgia Frog Rally 2018
aceinspp's Avatar
Yep takes a while but the stryofoam eventually gets cleared out. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
aceinspp is online now   Reply With Quote
