Old 06-08-2014, 10:04 AM   #31
bea60's Avatar
Yes, you think it would be that easy. Which is what the manual states. But when I hit the clock button, nothing happens. You also have the option of a 24 hour or 12 hour setting. But the key pad does nothing. I had the tech at jayco look at it. They also had no luck. The key pad does not function correctly.
2015 Rockwood 2604WS
2008 Toyota Tundra CrewCab Limited
bea60 is offline   Reply With Quote
Old 06-09-2014, 03:43 AM   #32
Hello,
We had the same problem with ours,pulled it out and took it to an authorized repair shop after contacting magic chef.
2013 Rockwood 8281SS
2006 GMC 1500HD 6.0L 4.10 GAS HOG!
Rochester, NY
rcnhoward is offline   Reply With Quote
Old 06-09-2014, 08:12 AM   #33
AKA: 'tiredTeacher
awellis3's Avatar
OK, I have to ask. Considering that everytime you set up, you will have to set the stoopid thing, and since it's digital, you will be compelled to do so to the correct minute so it and your cell phone have the exact same time, and you're camping ... you see where this is going? Why bother? Forget about it.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 06-09-2014, 11:37 AM   #34
bea60's Avatar
Yes, you are right.....we are camping. But you would think that when buying new it would work and not have to have it repaired. And no, I am not OCD having it to the minute with my cell. Your right, time shouldn't matter when your camping. I was just saying. Well at least I know I'm not going crazy that I can't set a simple clock. That someone else has had the same issue. Happy camping everyone.
Old 06-09-2014, 01:14 PM   #35
Witch Doctor's Avatar
I agree that's the first thing I do after set up one reason is that I know I have 110v. Just look at the display, NO display, NO power.....
Coachmen M/H
Concord
2018 / 300 DSC
Old 06-09-2014, 03:02 PM   #36
Timex's Avatar
I'm with you about if you're paying for something you expect it to work.
But have you had a kid under say age 10 try to set the clock? The kids these days can do wonders!
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
Timex is offline   Reply With Quote
Old 06-09-2014, 03:42 PM   #37
as far as your awning toppers, I have yet to see one that will dump rain unless you keep the RV tipped back a few degrees, they are not designed to shed water, mostly they fill up with water and sag. some people put 12" balls under the middle , me I just raise the Rv in the front when it rains.
bob34787 is offline   Reply With Quote
Old 06-09-2014, 07:51 PM   #38
My toppers and I have 3 have ever collected water in 2 years, you have the tension set wrong or not enough sloop when installed....
Coachmen M/H
Concord
2018 / 300 DSC
Old 06-09-2014, 09:08 PM   #39
bea60's Avatar
Topper
When they fixed my slide issue, I was told that two clicks were added to the back end part of the slide. And also the large topper was adjusted. I'm going camping next week, if we get any rain, I will see the results. Hopefully it will be sunny sky's all week long!
Old 06-09-2014, 09:37 PM   #40
camaraderie's Avatar
Glad most everything seems to be fixed for you.
Just for the future...there is a Rockwood dealer in CT and you could take the ferry over to make the trip manageable if you need anything major in the future.
Campers Inn I-84 CT
603-642-5555
2 Mashapauq Road
Union, CT 06076
camaraderie is offline   Reply With Quote
2604, camper
