Old 06-24-2019, 01:01 PM   #1
mattress dimensions 2104S Mini Lite
We are anticipating the delivery of our 2020 2104S soon. We would like to order some bedding in anticipation of its delivery. The dealer claims that the mattress size is 60” x 75” . However, I suspect that he measured an older unit as opposed to a late model 2019 or 2020, which are rumored to have a bit longer bed (60"x 80"). Could anyone with a 2020 measure theirs for me?
NebraskaKen is offline   Reply With Quote
Old 06-25-2019, 08:27 AM   #2
SeaDog's Avatar
the 60x75 is a short queen and the other a full queen either take the queen bedding.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 06-25-2019, 08:50 AM   #3
Grammar Pedant
67L48's Avatar
Amazon and other places have lots of options specifically for short queen bedding. We got some fitted sheets and they fit great.
RV: 2018 Rockwood Mini Lite 2504S
67L48 is offline   Reply With Quote
Old 06-26-2019, 10:39 AM   #4
Thanks to all of you for your useful suggestions. What I'm hearing is that sheets for both a short queen, or a regular queen will work. Thanks again, much appreciated.
Old 06-26-2019, 01:46 PM   #5
Smile
We replaced the stock mattress with an 8" memory foam and love it. It was a bit long but not enough to interfere with moving around.
RFGTLG is offline   Reply With Quote
Old 06-26-2019, 02:08 PM   #6
A suggestion for bedding fit:
Mattress Suspenders
https://www.amazon.com/s?k=mattress+...l_63zxfw0tjl_e
Standard queen mattresses are 60" x 80". Regardless of the size of your mattress, these suspenders will hold the fitted sheet in place and keep it snug. We use them on our PUP's bed...both the mattress topper and the fitted sheet. One set of suspenders for each item. We use the full corner-to-corner X-shaped suspenders and they do a great job.
As for blankets and the top sheet, I'd suggest harvesting a strip from old sheets/blankets and sewing it to the bottom of each piece of your bedding to create a much longer tuck area at the "foot" of the bed. Then, when you tilt the Murphy bed into the stored position, the longer tails on the bedding will keep the bed from falling apart. Extending the blankets with sheet material will keep the tucked area from being so thick that it raises the foot of the bed.
In fact, you could add a short section of fitted sheet to the foot of the top sheet (and blankets), or look for a top sheet that has a fitted bottom - we have that in our PUP's small, thin RV king bed. It's wonderful. I'm 6'6" and the top sheet never pulls out from under the mattress.
Jim & Renee
2014 Forest River/Rockwood HW 277
Typical season is about 30 nights camping, usually nearby boondocking in the National Forests or at Lake Wellington
jimmoore13 is offline   Reply With Quote
210, lite, mini lite
