Old 05-13-2014, 07:35 PM   #1
max water pressure
Does anyone know the max water pressure allowed with the plumbing in my RV ? 2014 Rockwood mini lite 2502s
gserve is offline   Reply With Quote
Old 05-13-2014, 07:44 PM   #2
Most systems 50 to 55 max. Did you check your owners handbook? They say some for 60. But I gauge mine down to 45 to 50. Hope this helps
Jerry. Vietnam vet.
Retired
jgahlhoff is offline   Reply With Quote
Old 05-13-2014, 07:47 PM   #3
VinceU's Avatar
Lowest fitting rating I've seen is 100 psi, most are 125. Manuf recommend 60 psi, reducers for hose inlet are 40-50 psi which may be low for some people based on piping layout. Pex piping is way up there near 200 cold. Best follow the mfg and max out at 60 psi or less.
Old 05-13-2014, 08:07 PM   #4
Witch Doctor's Avatar
The problem is not your plumbing, it can hold the pressure. It is the cheap plastic fixtures. They are not the same as your home. They are mostly held together with O rings and will blow at 65 PSI. If you changed them to household type you wouldn't have a problem the pex is strong enough. Same as the hoses that connect to your water pump. Same hose as you buy at the stores. the same hose as you connect to your city water. then it go's to pex. The shower and bathroom sink are the worst, they will blow first. The weak point of the pex is at the Tee's with the clamp fittings, but still that is not the real problem. You really need to stay between 45 and max 55 psi. and that's because of the fixtures.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Witch Doctor is online now   Reply With Quote
Old 05-16-2014, 08:28 PM   #5
Paul & Sheri
pwb01's Avatar
Use a regulator whenever you hook up to a city water supply. They're cheap and you won't have to worry about pressure.
2012 F150 F/X 4, 6cyl EcoBoost with Max tow pkg
2013 Rockwood 8280WS 5th wheel
2006 Sunline T1950
2004 T@B T-16
pwb01 is offline   Reply With Quote
Old 05-16-2014, 08:56 PM   #6
BamaBob's Avatar
X2 - if you are NOT using a pressure regulator well...flirtin with disaster!
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 05-16-2014, 08:56 PM   #7
Denver, CO
garbonz's Avatar
Good adjustable full flow regulators like watts with a gauge are not cheap, but are worth it.
http://www.rvwaterfilterstore.com/Pr...Regulators.htm
This new one may be an exception for those who don't need adjustable or with a gauge.
NEW PRODUCT!! Fairview 55 psi inline regulator with great flow. This is what everybody has been waiting years for. Expect little difference from what the spigot can put out. Not adjustable or repairable like the Watts units, but very economical with high performance for those not willing to go with the more expensive units.$24.95
2017 Fuse 23T
Old 05-16-2014, 09:00 PM   #8
Know, I have been. Do you need to replace them after a while? The one I have is over 7 years old.
Old 05-16-2014, 10:00 PM   #9
Denver, CO
garbonz's Avatar
The cheap one just have an orifice that reduces pressure and flow, and they may become clogged or reduced in flow more than normal, but if it is working for you, why worry.
2017 Fuse 23T
pressure, water
