Old 11-19-2015, 04:41 PM   #1
MaxAir Fan
In the bathroom stopped working...any ideas?? I checked fuses, only saw one for the bathroom but not one for the fan. It did work before.
2018 Ram 3500 SRW diesel 4x4 long bed Laramie
2020 Jayco Eagle HT 274CKDS
My Smoker Adventure:
https://www.youtube.com/watch?v=1BSZsmP5X78
Use code SPdiscount to buy on Amazon
spower is offline   Reply With Quote
Old 11-19-2015, 04:53 PM   #2
TURBS's Avatar
There should be a fuse right at the fan
Old 11-19-2015, 04:54 PM   #3
TURBS's Avatar
Maybe this?
Glass fuse.
Old 11-19-2015, 04:56 PM   #4
Mine has keypad (push button) no fuse that I can see on the unit.
Old 11-19-2015, 05:52 PM   #5
Make sure the light switch is on.
2015 Rockwood Roo 23IKSS
2015 GMC Sierra 1500
Archicamper is offline   Reply With Quote
Old 11-19-2015, 08:27 PM   #6
That was it!! I had no idea the light had to be on. That is why I love these forums!!
Thank you!!
Old 11-19-2015, 09:47 PM   #7
Klbrown53's Avatar
Light switch happened to me once also.......
We have 2 light switches, one for over head and another for over the sink. I can never which one so I turn both lights on when I shower and run the fan.
Klbrown53 is offline   Reply With Quote
Old 11-21-2015, 12:09 AM   #8
RangeMaggotBob's Avatar
Eegads! I didn't know that! Now I'm going to have to go home and try it!
2015 Forest River Rockwood Signature Series Ultra Lite 8289WS w/Diamond pkg.
2014 RAM CTD 6.7 Tradesman 4WD Auto Crew Cab Long Bed
Honda eu2200i generators
RangeMaggotBob is offline   Reply With Quote
Old 11-21-2015, 11:30 PM   #9
gectisme's Avatar
My Bathroom Fan runs with or without the light switch on. I guess some do some don't...
2016 Windjammer 3006WK - Sold July 2018
2002 Lance Lite 835EC TC - Sold July 2015
2010 Dodge Ram 2500, 4x4, Diesel, Front Hitch, Air Lift 5000 Rear Air Bags, Sold Mar 2019.
MISSION COMPLETED!
gectisme is offline   Reply With Quote
Old 11-22-2015, 12:13 PM   #10
Klbrown53's Avatar
Interesting.
I just remember that the first time it happened to me I had the fuse out looking at it and it was good. I figured the fan had gone bad. Next night it worked so then I started looking for the reason why.
Old 11-22-2015, 02:45 PM   #11
I was thinking about this and I have a thought on how to "fix" (change) this.
When I got my Mini Lite, the light switch wasn't full seated on the wall. For some reason, they'd put a whole ton of RTV on the wiring. I pulled the switch out and had to cut off all the RTV to make it sit flush again. I noticed that there were two wires on one switch connection and one wire on the other. I'm assuming that the single wire was power (+12VDC) and the two on the other contact were one to the light and one to the fan. Seems you could remove the one from the fan and splice it directly to the power wire and eliminate the switch from the fan circuit.
I may try this; but my problem is my bathroom has TWO lights. If one wire goes to the light above the sink and the other goes to the fan and then on to the other light, I won't be able to. I guess an experiment is in order next spring.
2011 Traverse LT, 3.6L, FWD
fan
