Old 04-26-2016, 08:16 PM   #1
Maxxair fan vent won't open
We just spent out first weekend camping at the Bourne scenic park on the cape cod canal. First real tow. First back in. First setup. First hookup. First strike camp and first dump station. Whew! It's like being plugged into the matrix...there is so much info to absorb.
Only 3 issues.
You can't back up the rig with the emergency brake on...
I couldn't flush the black tank through the winterizing inlet D'oh!
And finally my galley maxxair fan turns on but will not open. If you open it manually then hit close, it will close. It doesn't open with remote or button on fan.
Is it defective or am I missing something?
Thanks!
Some must watch while others must sleep
drstimpy is offline   Reply With Quote
Old 04-26-2016, 08:21 PM   #2
Ford Idaho's Avatar
Mine can be set to work like a ceiling fan, fan turns but the door will stay closed.
It's in the manual, which I can not get to right now....
Air in/out button?
Old 04-26-2016, 08:37 PM   #3
Yeah. That function works but when you hit open...it doesn't. Though the remote says it is open
Old 04-27-2016, 03:56 AM   #4
Ford Idaho's Avatar
I will work with mine after daylight to day and see if I can repeat.
Old 04-27-2016, 05:22 AM   #5
Oakman's Avatar
If you have the rain sensing feature on your vent then there might be moisture on the sensor itself causing it to remain closed. Just a thought.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 04-27-2016, 06:06 AM   #6
rattleNsmoke's Avatar
Try pushing the open\close knob in (upward). It may be pulled downward into the 'manual' position.
rattleNsmoke is offline   Reply With Quote
Old 04-27-2016, 06:08 AM   #7
I turned the rain sensor off and tried again...no go.
Good idea though.
Be a pity to haul it back just for that!
Old 04-27-2016, 11:49 AM   #8
Check the temperature settings: the inside is most likely set too high. Drop it 10 degrees and the problem goes away.
6331 is offline   Reply With Quote
Old 04-27-2016, 01:56 PM   #9
Ford Idaho's Avatar
I played around with mine.
Knob to open the cover lid does not pull down or push up.
Mine does not have the rain sensor so it is clearly a different model.
Sorry I am not much help.....
Old 04-27-2016, 09:20 PM   #10
Rodgers's Avatar
Only 3 issues.
Thanks!
We have had that issue. The cover gets stuck don't know why. You have to get it unstuck manually then it will open. Mine does it all the time.
Rodgers is offline   Reply With Quote
fan, vent
