Old 06-08-2019, 03:18 PM   #1
Freetyme's Avatar
Maxxair only runs on high
Have the Maxxair exhaust only fan, 4 speeds no remote. It starts, but stops in a few seconds on speeds 1,2,3. If I cycle immediately to 4 it stays running. Ive noticed this on a few occasions and next time will work normal. Any ideas wtf is going on.
Freetyme is offline   Reply With Quote
Old 06-09-2019, 11:39 AM   #2
SeaDog's Avatar
I would pull the fan and check the fan control switch connections for corrosion or loose connections.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 06-09-2019, 10:10 PM   #3
Freetyme's Avatar
Thanks Sea Dog, seems there may be a known issue with the circuit board I discovered on YouTube. Contacted Airexcel, mfg. of the fan. Will see where that leads.
